MPXF TSR problems
Has anyone had problems getting the Song info to display? I load the tsr and mpxf seems to work fine, but when the song plays no information is displayed..
does anyone have any suggestions?
I have the same problem. Dont know how to fix it either. I know you have to do somthing with mpxftsr.exe.
Ok, first off here's how the mpxftsr works. It basically is a program that stays resident in the systems memory (TSR) and copies certain lines of the Mpxplay display to the LCD. Yes it has to run under DOS (mode- not in a window) to work, and yes you do have to go into the TSR config file to get things working properly.
The TSR doesn't actually read the ID3 tag from the song, mpxplay does that. The TSR just picks a few lines out of the Mpxplay on screen display and throws them out to the LCD. If you are running anything other than the default display of Mpxplay, you have to tell the TSR to compensate (though I haven't quite figured that out myself).
If you are seeing things ok when running MPXF, then I assume you got Mpxflcd.cfg working properly. Have you done anything with Mpxftsr.cfg? Are you running the TSR at all?
There's lots of info at on the MPXF discussion boards at http://www.radioactivesoft.com/default.htm
Be sure to check that out.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
