Results 1 to 9 of 9
Thread: A simple 60 minute sound recorder ???
    Aug 2000
    Abbotsford, BC, Canada
    Post A simple 60 minute sound recorder ???
    Hi all - Does anyone know of a simple (one-time use, then I'm gonna blow it away) sound recorder that will record either form a microphone (I'm not lookin for Hi-Fi, here) or from the headphone-out jack on a micro-cassette recorder to th einput on my sound card.
    I've found that the recorder that ships with MS has a 1-minute limit, and I need an hour.
    The final formats I want are MP3 and audio CD (wav).
    Thanks, everyone :}
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    The stuff that comes with sound blasters does over a minute... Creative Wave Recorder, I think.
    you can probably get it at www.sblive.com
    Jan 2001
    Post
    Simple trick with ms sound recorder: Download a 60 min audio file with blank stuff on it and just use that as your template. You can write over it if you want. Just keep in mind sound recorder is a #$@$@%$@# program, and really handles memory usage poorly.
    Aug 2000
    Post
    'Scuse the ignorance... does it have to be in any specific file format, BGreet?
    ~m
    BC ROCKS!!!
    Sep 2000
    North Carolina
    Post
    This should work (I Think):
    Record a 60-second sample in recorder. Now select copy, and then paste. You now have a two minute sample. Do a copy and paste for however long a sample you need.
    Now hit record and it should record the length of the sample in memory (beyond the 60-second limit).
    Jan 2001
    Post
    Dos: I believe sound recorder only works with wav file format. Wav is basically the standard for everything, and you can convert it later to mp3 or whatever you want using a converter program. Good luck!
    Feb 2000
    Post
    You also can use Musicmatch jukebox, it lets you record directly from the mic input or line input to mp3 format without that limitations, you can download it at www.musicmatch.com (i guess this is the url), good luck Sherlock...
    Aug 2000
    Talking
    Thanks, guys! I think I'll try the Musicmatch method. FYI, it's a recording on a digital recorder that I want to transfer to CD. I made it when my 2nd son was born (4 mos ago)...It was a planned C-section, and I sneaked the recorder into the Operating Room...Recorded his first cries!!! :} (and he hasn't stopped since )
    Thanks again, all.
    ~m
    BC ROCKS!!!
    Nov 2000
    Wisconsin US
    Post
    I was just fooling around with this last weekend.... no not sneaking into dilivery rooms and recording it! well... story for another time.
    anyway the program i use is soundjam. This is the same program i use to rip my cds out and i found this feature to work great. I actually used it to tape a radio program. it converts straight to mp3 which is nice. Even has a sleep feature build in so it stopped when i wanted. great cause i was gone and needed the program taped at a certain time and this allowed me to do that.
