Results 1 to 5 of 5
Thread: Disabling safe mode in Windows ME?
    Jul 2000
    Jackson, MS, USA
    Post Disabling safe mode in Windows ME?
    Whats the method to disable safe mode in Windows ME? I looked in msconfig but I didn't see an option to disable safe mode.
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    There is a piece of software I think it is called Xsetup that is similar to TweakUI only about 50 times as many options.
    http://www.xteq.com is the site but I got it from download.com (I think)
    http://www.geocities.com/mr_bubba_zanetti/
    Jul 2000
    Jackson, MS, USA
    Post
    I have used the XSetup software before and there isn't an option to disable safe mode, only an option to disable scandisk.
    2000 Honda S2000
    Nov 2000
    VA , USA
    Post
    errr these are msdos.sys settings
    check out the webpage
    http://www.physiol.ox.ac.uk/~trp/msdossys.html
    look at the info on bootwarn, BootMenuDefault, and maybe BootSafe also (info from the url included below)
    I would test these out to see if I could figure out what you need from it but I am at work and only have my win2k machine to work with so I cant do that right now.
    BootWarn=
    Default: 1
    Purpose: A setting of 0 disables the safe mode boot warning message and
    the Startup menu.
    BootMenuDefault=
    Default: 1 if the system is running correctly
    3 if the system hung in the previous instance
    Purpose: Use this setting to set the default menu item for startup.
    BootSafe=
    Default: 0
    Purpose: A setting of 1 forces your computer to boot in safe mode.
    [This message has been edited by moxnix (edited 02-12-2001).]
    Oct 2000
    DFW area
    Post
    ur right, Xsetup has a lot of options but not to disable safe mode.
