Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Change taco needle colour with engine RPM
    Dec 2004
    QLD, Australia
    A tacho/speedo whose needle changes colour while in a certain rev range. ie from 0-2500rpm needle is white; 2500-5000 needle is purple; 5000-few hundred rpm below redline needle is orange and above that would obviously be a red needle. I borrowed the idea from an episode of Top Gear where they reviewed a 70,000pound beast.
    Would probably be best applied to the OBD dashboard projects going on.
    Anyone have the programming skills to know where to start? Any DirectX programmers reading?
    Rode-B[O]X: scrounging components
    Bits I bought:
    Xenarc 700TSV | DSSC | GPS18PC
    Pieces Im looking at:
    Axus TC600 WINXPe | EPIA * | GPS gadgets
    Constant Bitrate OdysseyPC's Avatar
    Oct 2003
    ACT, Australia
    Quote Originally Posted by trillion
    Would probably be best applied to the ODB dashboard projects going on.
    I'm guessing you mean a software speedo??
    If so that's a fairly simple implementation, i'm sure those working on the digital guages could support that easily.
    Caputer Mk. II
    '02 VX Holden Commodore Series II Executive
    MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
    Morex 60W DC-DC, Custom S/SDC
    OS/Software: Developing...
    Dec 2004
    QLD, Australia
    Deactivated Diewlay Lowmo's Avatar
    Aug 2004
    So sick.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Thats easy, just have a multicoloured LED in the root of the needle and a switches that are activated when the needle passes them - eg rotory encoder onthe back or something
    Jan 2003
    Ruston, LA
    I prefer my taco's without needles thank you.
    Hot sauce is much better for that extra kick.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Variable Bitrate danon's Avatar
    Oct 2003
    Queensland, Australia
    would be nice to see the color morphing in between and not just switching.
    [....99.9%]
    [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
    [....99.8%]
    [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
    [Working on] puttingBackEvrythg.
    Dec 2004
    Use something like all the recent pens and such use that switch colors. 3 or 4 leds that light up by themselves and in union with the others to create several colors...
    Dec 2004
    A friend of mine had one of these ice cubes that change colors....pretty cool
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=4345852861
    Dec 2003
    just do it mechanically
    get a couple 3mm or surface mount high-output LEDs and arrange them so that the tach needle gets lit up by them successively.
    Like, have the red one pointing at the right angle for the redline, and the purple one next to it so it lights the needle up that way and so on.. (i'd post drawings but you guys can figure it out)
  1. Change volume with Engine RPM
    By FunkDaMonkMan in forum Software & Software Development
    Last Post: 01-01-2005, 12:27 PM
  2. display colour change?? (green bulbs?)
    By Jinx in forum LCD/Display
    Last Post: 11-23-2004, 07:42 PM
