Results 1 to 10 of 12
Thread: Can a bat file do this?
    Feb 2001
    Cottonwood, AZ USA
    Post Can a bat file do this?
    I just wanted to know if a bat file could be made to close winamp, and then shutdown?
    if so can you post the code?
    thanks
    --BLK
    Wide awake
    and keeping distance from my soul - Tool
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    No.
    I highly doubt that.
    A small windows app could, but not a batch file.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Cool
    What are you talking about?
    Sure a bat file could shut down Windows!
    format c:
    and when the computer locks up, just flip the power switch. simple...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Post
    Yeah...just a couple of lines of code and a compile and you could write a little console app to do that. If need be you could call it from a batch file.
    Feb 2001
    Long Island, NY
    Post
    I have written a MP3 car control app to allow me to use my numeric keypad to control winamp (i had a plugin but i found it lacking) However, I am an idiot when it comes to leet programming and used VB (my mind is too simple to comprehend C++) but I could make you an app or give you the code in VB to make a prog that at the command line can perform functions controlling winamp and the Windows UI. Of course if you are using Windows 98 or 95 you can just as easily use VBscript with Windows scripting Host (I don't know its API capabilities, but I imagine it has the API capabilities that VB has. Check out my site if you want to know more about my prog.
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    PatO: that is really funny.
    Blackout why and what does ur player consist of. Have u looked at other apps? They prolly already have those features.
    abcd-1
    Author of CobraI and CobraII.
    For more information on the COBRA Application's please visit the link. For the latest or updated info on CobraII please click on the link. Get new updated files for CobraII here. ftp://pictures[email protected]/d:/newdlls
    You can contact me on AOL instant messenger....nick is Cenwesi
    Webpage comming soon!
    Official Cobra Page
    abcd-1
    Constant Bitrate monger's Avatar
    Nov 1999
    Good ole Maine. Gotta love trees and deer.
    Thumbs up
    If you are running windows ( which you are...) just create a shortcut on the desktop with
    target: C:\WINDOWS\RUNDLL.EXE user.exe,ExitWindows
    Start In: C:\WINDOWS
    You can also set up a shortcut key to set this off whenever that key is pressed.
    Ex. Shortcut Key = del
    press del and thats all.
    And yes, this will work in a .bat file. I just tried it on the spare copmuter sitting next to me....
    As for shutting down winamp, I dont see why thats necessary. Just shutting down the copmuter will work fine.
    Have fun
    Monger
    ICQ-7207702
    Monger
    ICQ-7207702
    UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
    Feb 2001
    Cottonwood, AZ USA
    Post
    That sounds like it would work great, but is there a way to set the shortcut key in windows, I don't really want to add to my start up time with a macro program or something, I am going to be using just a number pad also (ie. 17 keys), so could it be a combo of keys like enter and / or something of the sort?
    thanks for the help guys,
    --BLK
    Wide awake
    Jun 2000
    Salt Lake City, UT, USA
    Post
    Sure.
    Just right click on the shortcut and choose properties.
    There a line in there called shortcut key. Click your cursor where it says NONE and type the short cut you want. You will see that "NONE" is gone and your shortcut is there now.
    Save your work and try it out!
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
