Results 1 to 9 of 9
Thread: markuszehnder lcd plugin
    Mar 2001
    Perth, Australia
    Question markuszehnder lcd plugin
    am i the only one that cant get this to work, i unzip to plugin directory then wimap wont load, it tries to but comes up weird and i have to ctrl+alt+del and end task.
    i cant get it to work, any ideas ?
    May 2001
    Post
    it might be your winamp version. if you are in winnt/2k you have to download the special portio dll on his site. best of luck
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    Jun 2001
    San Diego, CA
    Post
    Maybe your plugin output is set wrong, to a serial output instead of parallel(remember to stop it if it's started before you change), I recommend onscreen simulation first.
    Make sure before you start playing songs, the vis plugin is spectrum analyzer, and the general purpose plugin for the lcd is configured correctly.
    Also edit the gen_lcd.ini with the data from the samples so you can get a descent idea of what it can do.
    Mar 2001
    Perth, Australia
    Post
    im using win98 but aslong as the plugin files are in the plugin dir or winamp i cant load winamp up to change any vis output settings? winamp just crashes while loading b4 i can change the settings or select the plugin
    mpt
    mpt is offline
    Jun 2000
    Setubal, Portugal - Europe
    Post
    First, goto the plugins directory and rename the vis*.dll and gen*.dll to .old to disable the plugins. Then try to open Winamp and see if it crashes. If not try renaming plugin files one by one until winamp crashes. It might be a plugin conflict. I had a similiar problem with winamp plugins and this was the solution.
    mpt
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    Post
    Using the .4b on win95 and 98 it keeps crashin'with me to. However with the .5A i don't have a problem.
    peter3
    p133 4.3G 16Mb 2x16 ac-dc
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Apr 2001
    Post
    I TRYIED TO GET HIS PLUGIN TO WORK, BUT IT NEVER WORKED. EMAIL HIM A FEW TIMES BUT NEVER HEARD BACK. LOOKS LIKE HE HAS A GOOD PROGRAM THAT CAN MAKE CUSTOMIZING THE OUTPUT EASY. NOW IF IT WOULD JUST WORK WITH MY SETUP.
    DOES ANY ONE KNOW IF THE PREVIEW VERSION WILL WORK WITH THE CF632 OR OTHER CF LCD.
    I'AM RUNNING WINDOWS 98 WITH CF632. AND THE LCD COMES UP BLANK WITH A CURSOR. LCD IS GOOD USE TO WORK FINE WITH MPXF.
    LATE,
    MP3DOG
    Feb 2001
    Post
    Just got my 2 lcd from eio.com
    a LM4034 and a L2014 wired them bouth
    and tested with lcdprint and it worked.
    But this plugin will work only with the 4x20
    not with the 4x40. I have tried divernd output variations but nothing seem to work.
    Using only row 1 nothing's wrong.
    Using row 1 and 2 nothing's wrong
    Using row 1,2& 3 row 3 moves to row 2
    Using row 1,2,3&4 row 4moves to row 1 and 3 to 2.
    Is it in the plugin that somthing goes wrong on a 4x40
    Let me know what your exp. are
    [email protected]or[email protected]
    I really want to know so that i can use this great plugin.
    peter3
    Feb 2001
