Results 1 to 3 of 3
Thread: Bootskin problem
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Bootskin problem
    I changed my bootskin on my computer. Now I have a problem. Everything works fine. Windows loads, no problem. But at bootup it acts like the bootskin is a whole different OS. (You know, like when you've got 2 versions of windows installed it prompts you to choose the one you want)
    So I have to select the bootskin windows.
    What's up with thta and how do I make it go right to the bootskin version?
    Jul 2004
    NL, Druten
    Open boot.ini on your active partition, normaly c:\
    The file is hidden but can be opened in an explorer like this c:\boot.ini
    modify the file.. but be aware, it's a very dagerous action if you don't know what you're doing.. mini looks like this..
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
    Dec 2004
    Baltimore, Maryland
    Quote Originally Posted by TheKingPlaza
    [boot loader]
    timeout=30
    [operating systems]
    Right. That's what the bootskin program does is modify the boot.ini file. I don't know how to alter it myself to make it do what I want.
    Can someone break down what the relevant steps in the process are?
    And I've screwed up the boot.ini file before and learned the hard way to save it before you change anything. That's a hell of a good safety tip TheKingPlaza gives.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  3. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  4. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 08:47 AM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
