Use VNC instead. See http://www.uk.research.att.com/vnc/ for info.
Hello everyone!
Well I know this has been covered using the pc anywhere for ce. But, on my hp 320 lx I can not for the life of me get ce anywhere to work. I was wondering if there is anything out there like http://www.giantdisc.com/ but for windows ce instead? A program that conencts to a computer via and the pc is used to played mp3s and controlled via the handheld device. Anyone heard of such a project? Check out <A HREF="http://www.giantdisc.com/!!!
" TARGET=_blank>http://www.giantdisc.com/!!!
</A>
-Jason![]()
Car
1964 Ford Falcon powered by a 1993 Mustang 5.0 EFI, AOD transmission, with disc brakes up front and more mechanical goodies
The Player
Gone! Soon goign to repalce the screen based system i HAD with an iPod. http://mp3falcon.crazyshaxs.com
nice... Ill have to download it and see if it will run on my hp 320.
-Jason
Car
The Player
What's giantdisc?
see my first post.
-Jason
Car
The Player
byaroch, have you tried getting the giantdisc software to work like this?
-Jason
Car
The Player
I have not tried it. I would need a nic and a PC with the software on it.
However I don't see why it wouldn't work.
Also I looked at the scripts....it should be fairly easy (for someone with programming expirence) to make a CE version of giantdisk.
Do we have any takers? (should be easy to impliment with embedded VB)
You might want to try this
http://www.cs.utah.edu/~midgley/wince/vnc.html
you could run winamp on a pc and VNC into that machine
I use palm amp.
I have looked at vnc.But I cant get it working verry well over the serial port.
I also have some software called pebbles PC http://www.cs.cmu.edu/~pebbles/
They all do verry similar things.
Except palmamp is really a customized interface to winamp.
