Results 1 to 10 of 11
Thread: Request: Need an app to bring other programs to the foreground
    Oct 2004
    East Sussex, England
    I'm looking for a program that I can run with a command line parameter which will bring any other running application to the foreground.
    For instance.. if I have proga.exe, progb.exe and progc.exe running I might want to bring progb.exe to the foreground.
    specialprogram.exe "progb"
    Does anyone know of such a program? Or could someone knock one up for me?!
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    It will depend entirely on the nature of progb.exe and if it permits multiple instances of itself in memory. -- else we'd have to search for the particular PID and bring that to the foreground.. possible but difficult if you have more than one and you're picky 'bout which gets brought up front.
    If progb.exe only permits one instance of it's self, why not call it instead of specialprogram.exe ?
    •Micke
    Oct 2004
    Well it would probably be Destinator. Which allows multiple instances. So I would need a particular instance brought back.
    Couldn't specialprogram.exe enumerate all the running process and then look for the closest match to the one specified in the command line parameter?!
    I don't do windows programming.. :-(
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    By your description, you want something like pressing ALT+TAB key. If so, look for "little task switcher" in the OS optimization forum.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jul 2004
    VaBch VA
    some simple vb.script can do this via sendkeys but landing on 'progb.exe' may be a bit dodgy. http://msdn.microsoft.com/library/de...thsendkeys.asp
    •Micke
    Oct 2004
    Quote Originally Posted by MatrixPC
    Nothing found!
    Oct 2004
    Jul 2004
    VaBch VA
    that looks promising.
    •Micke
    Oct 2004
    I wonder if I can maximise the app too...
    Constant Bitrate Ill1's Avatar
    Jun 2004
    Woodbridge, VA
    www.AutoHotkey.com
    You can do a lot of things with the scripts you write with this program.
    ________________
    ______ILL.1______
  1. Switcher - A little button app to Alt-Tab between two programs.
    By LESLIEx317537 in forum Other Cool Stuff
    Last Post: 12-23-2004, 07:47 PM
