Results 1 to 10 of 19
Thread: Okay, guys, I need some help....
    Low Bitrate dapepster's Avatar
    Jul 2001
    Jerome, ID, USA
    Unhappy Okay, guys, I need some help....
    I'm a bit confused as to what to do next in my carputer. I guess it'll be easiest to tell you what I have and what I want to do.
    So, here's what I have:
    P-100, ESS 1688, Seiko L4034 4x40 Display, numeric keypad
    Here's what I want to do with it:
    Ability to play MP3s with MULTIPLE playlists (as far as I've seen a large number of the plugins/programs only work with ONE playlist...), and be able to browse through the list of songs on my LCD by using the keypad using EITHER DOS or Win95.
    Anybody know what program/plugin would be best for me? I've been thinking the ongest time about MpxPlay, but I'm not sure still....
    Please help!
    May 2001
    Post
    Athlough I have no experience with mpxplay, it sounds like your best option. I believe there are a few frontend tsr's out for it that can do the things you want to do. DOS is definitely the best OS to go with considering your cpu speed, contrary to what some other people...or one other person...might believe...no names I dont know of any of the frontends right off the top of my head, try searching through old posts for something like "mpxplay frontend" or something.
    actually...just check out these sites...
    http://www.multimania.com/screamers/mlt/ http://www.radioactivesoft.com/mpxf/index.html
    [ 08-16-2001: Message edited by: pinkysqueaks ]
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    May 2001
    Toronto, Canada
    Post
    Win-95/98 should run quickly enough on a P-100 provided you strip it down. As for the multiple playlists, use Markus Zehnder's LCD plugin for Winamp. This plugin does exactly what you're looking for - you can scroll htrough your songs/playlists on the LCD using the keypad. It's a great plugin!
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    Post
    MTMSOL is right.
    I used it on a P-90 whit win95 os2 and it worked great.
    When you use your L4034 remember to set the display config on splitscreen it toke me 2.5 days to figure it out(must read the text before u do anything i gess ;-) )
    Peter3
    P133 Win 95 os2 4.3Gb 16Mb ram
    Questions?
    pwvanderveen@hotmail.com or
    peter.wendy@keyaccess.nl
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Jul 2001
    Jerome, ID, USA
    Smile
    Awesome! Thanks guys, for all the help!
    Low Bitrate radioman193's Avatar
    May 2001
    Dansville NEW YORK
    Thumbs up
    Cobra III Dude!
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Post
    some small aditions to these excellent suggestions: You can find software to strip down Win98 to run as fast as Win95 at
    http://www.98lite.net
    And a plugin for doing multiple playlists in Winamp is Albumlist. I use this constantly...it is an excellent piece of software
    Jul 2001
    Post
    NO!!!!!!!!!!!!
    go for MPXPLAY!!!!!!
    you'll be booting in about 15seconds...
    And with my P100 in windows the graphic EQ laged when playing MP3's and paused when scrolling through my playlist..... Go for dos..
    Aug 1999
    Upper Marlboro, MD 20772
    Thumbs down
    skinny boy When you are READY for a real setup, windows will be waiting 4 u. I wont even comment about dos or ur setup but u know where i stand
    abcd-1
    Jul 2001
    Jerome, ID, USA
    Thumbs up
    Thanks, guys. Don't bite each others heads off, though! I'l try all of them and see which one I like, then I'll go with that.
    BTW, another question: Has anyon used or have experience with GMenu 1.0? And is it any good?
