Results 1 to 6 of 6
Thread: auto-off atx + windows 2000 hibernate
    May 2001
    Post auto-off atx + windows 2000 hibernate
    Has anyone configured this to work? For some reason I can't get windows to hibernate, I get the notification that there has been a power failure...but thats it. Theres not a whole lot of stuff to configure...I can get it to work with APC's powerchute software...but that won't let you hibernate
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    moahdib's Avatar
    Jul 2000
    Post
    which auto off atx is this?? dschidt? YOu may want to try with Jeff's atx poweroff. I was able to do both hibernation and shutdown with no software to configure... only set winMe or 2000 to hibernate when power button is pressed.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    May 2001
    Post
    its a dschmidt, no worries though. I solved the problem myself by writing my own software to watch the serial port and put the computer into hibernate i haven't even heard of jeff's power-off- is there a howto?
    moahdib's Avatar
    Jul 2000
    Post
    Yeah here is info for delayed auto-off for ATX. You can read the thread here about what it's about... http://www.mp3car.com/cgi-bin/ultima...c&f=9&t=000119
    Click here for parts list www.mp3car.com/usersites/moahdib/shutdown.doc
    Here is the schematic: http://www.mp3car.com/usersites/moahdib/atxshutdown.gif
    I like it cuz it doesn't take up a serial port and you can adjust the timing for everything adding pot's, all parts cost only ~$15.
    My TL CarPC ver2
    Aug 1999
    Yorba Linda, CA
    Post
    pinkysqueaks -
    How did you get the computer to hibernate from software? What API call(s) did you use?
    --Jason
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    M²PC Phase IV - *** PENDING ***
    cj
    cj is offline
    Aug 2001
    Post
    Here are two links that will show you how to hibernate from the command line:
    http://www.losoft.de/fs_lstools.html - This link is to a command-line utility that supports hibernate from W2K, but I'm not sure about other OS's.
    http://www.jsiinc.com/subg/tip3100/rh3153.htm - This link will show you how to use the Windows Scripting Host to hibernate your machine. Pop it onto the command line or make a shortcut for it.
