Results 1 to 6 of 6
Thread: Sound not working in Dos
    Mar 2001
    Cincinnati, Ohio
    Question Sound not working in Dos
    Ok, I have a built in CS4232 Sound card on my mobo. I want to use it in Dos for mpxplay. It works fine in windows. When I run mpxplay in dos, it won't work, so I installed the dos drivers, which make my card a SBpro compatible card. it puts that in the Dos startup script. When I boot down to dos, I see it run that program and tell me my info on the card. Mpxplay still won't work. When I run the sound card config for mpxplay (mpxplay -scm) it says "unknown card: MID"
    Could this be caused by running the Dos 6.2 version on Dos 7? I thought they were compatible though.
    Please help me! This is annoying.
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Nov 2000
    Post
    No 6.2 or 6.22 and 7.1 or 7.11 are not compadable. Most of the commands will not run on eachother. If you are running dos have you ever considered not having windows boot at all and going strait to a doss prompt? I'm not really shure how you have it set up.
    Feb 2001
    Post
    Originally posted by lstrunk:
    <STRONG>
    </STRONG>
    Are you talking about the Pmode/W version of MPXPlay? I've been running MPXPlay 1.42 Pmode/W on my DOS 7.1 - based machine without any problems.
    If you're running MPXPlay 1.42, try editing the mpxplay.ini file and changing the 'sound card type' from 0 (autodetect) to 14 (SB Pro) or 3 (WSS).
    Also, you may wish to take a look at this newsgroup posting. Link
    [ 11-08-2001: Message edited by: bh76 ]
    Mar 2001
    Cincinnati, Ohio
    Unhappy
    Thankyou very much.
    Feb 2001
    Post
    I came across an article which describes how to put a CS4232 into WSS mode (This would beat SB Pro emulation by a long shot). Then MPXPlay 'should' see it as a "windows sound system compatible" sound card.
    Link
    If you can get this thing to work, you should be in pretty good shape. The Crystal sound-chips get pretty good ratings in the area of sound quality. http://www.pcavtech.com/soundcards/compare/index.htm
    I'm having the exact opposite problem. My Vibra 16 card works fine with MPXPlay and was easy to set up, but the sound quality leaves a lot to be desired.
    [ 11-11-2001: Message edited by: bh76 ]
    Feb 2001
    Post
    Replaced the Vibra 16 card with a cheap Pine Technologies ISA sound card, which is based on the CS4235 chipset.
    The sound quality was pretty good compared to the Vibra 16.
    It was a pain to set up, but I got it to work with MPXPlay in WSS mode.
    I removed the sound blaster drivers from the autoexec.bat and config.sys, removed the "set blaster" string from the autoexec.bat and then used the following settings:
    File: Cwdaudio.wcm
    [PNP]
    WssIO=534
    WssInt=5
    WssDmaPlay=1
    WssDmaCapture=0
    SbIO=Disabled
    OplIO=Disabled
    OplInt=Disabled
    4232IO=Disabled
    4232Int=Disabled
    GameIO=200
    MPU401IO=Disabled
    MPU401Int=Disabled
    CDIO=Disabled
    CDInt=Disabled
    CDDma=Disabled
    Device4IO2=Disabled
    Device5IO=Disabled
    Device5Int=Disabled
    File: autoexec.bat
    c:\crystal\cwdinit.exe /o /c c:\crystal\cwdaudio.wcm
    SET ULTRA16=530,0,1,0
