Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Writting code in VB to control a LCD?
    Sep 2001
    Post Writting code in VB to control a LCD?
    Does anyone know how to do it? I know vb, but have no clue how to do it? Know of any tutorials? Or dll's that can be used with vb to work with lcds?
    Nov 1999
    Ishoej, Denmark
    Post
    I assume you mean a Character base lcd, these can be controlled two ways either by parallel port or by serial port. VB doesnt really allow you to utilize the parallel port. It may be possible to do it by api calls i'm not sure. The only true way is serial but it will require that you put a small controller to handle the serial inputs (i can remeber where i saw it but it is doable).
    Your best shoot will be using a dll to handle the parallel communication, however my experience is that very few of the people that has made this type of code will make it available, however i know there is at least one, because i messed around with it.
    However i wanted to do a bit more than the dll was able to handle (i wanted to use inputs on the parallele port, but reaction times where just to high)
    i have one of the few available dlls, but i cant remember where i found it. i have two names you can search for directio01.dll and ximp. i believe this is the name of the site, i dont know where it is located but try searching for ximp, if you cant find it ill try'n make it avail to you
    Sep 2001
    Post
    Yea, I figured I was going to have to go through some kind of DLL.. I'll se if I can find it, thanks..
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    May 2001
    Toronto, Canada
    Post
    If you do decide to go serial, check out this link. Haven't tried it myself, but it looks interesting.
    Sep 2001
    Post
    Thanks you two, I think thoes are exactly what I needed..
    Nov 2000
    VA , USA
    Post
    if it is a serial LCD let me know since I have done quite a bit of programming in VB for the serial LCD display for winamp.
    Sep 2001
    Post
    I am hoping to use serial, since it's faster correc..
    Any help would be great. I was going to write my own media player also, to include everything I need.
    Registered User
    Apr 2000
    New Concord, OH, USA
    Post
    I wrote a VB app to control winamp and use an LCD class module to display info on the LCD when winamp doesn't have control of it (ie.. in car ripping) It's been awhile ago but the web site in the source is www.mscar.cjb.net I think you also need a dll (WIN95IO.dll) to control the lpt port. I don't think it works on NT or 2000 but I'm running it on 98 with no problems. Let me know if you need more info.
    Dan
    Dan is offline
    Mar 2000
    Odivelas, Portugal
    Post
    I wrote the LCD CLASS in vb to control a parallel port lcd (it works in win95/98) you can download from http://homepage.oninet.pt/400mjj/download.htm
    The mscar system is almost finish.
    MSCAR - Multimedia System Car
    danbar@oninet.pt
    danbar.mscar@oninet.pt
