Where the OS comes from has nothing to do with the hardware working with it.
You can't just install an OS though and expect a cable modem to work with it. You need to set up the networking to use the cable network. I'm assuming you're using @home. So you'll need to do certain things. In the network configuration, you need to set your gateways as supplied by the service (there should be a piece of paper with all that IP information on it). You also need to set the computer name appropriately and the work group to @home (if you're running @home). Those few things are the most important, other than configuring to use LAN for internet, which you've already done. Hope this helps you...
-Wes-
LinkBack URL
About LinkBacks
I have read that if you have an oem version of win98 some store bought computers will give you problems with networking and so on....
