Results 1 to 10 of 13
Thread: One button shutdown
    Apr 2001
    Schaumburg, IL (NW Chicago Suburbs)
    Post One button shutdown
    Is it possible to have a program for an ATX mobo that when the button is pressed like 3 times in a row or somethin, it will shut down? I'm thinkin that this would be possible considering that the button contacts go into the motherboard. Just interested now cuz I have a ATX mobo in my car! Thanks!
    -Kev
    Jan 2001
    Post
    Im not sure here, but I have heard of something called "shutdown cards". Something you can stick in your computer that controls the shutdown process, so all you have to do is press a button. Im not sure this is what you meant, but it might help.
    - Experience varies directly with equipment broken ---------- Kevmo
    Apr 2001
    Post
    Now that I think about it, you can do it through the serial port. If you look at the back of higher end UPS's (Uninterruptible power supply) they have a serial port and you can buy the cable and software so if it sees that theres no power, it shuts the pc down automatically before the battery on the UPS wears out.
    -Kev
    Apr 2001
    Post
    UPS
    Includes User Manual , Velco Cord Management Straps , Smart UPS signalling RS-232 cable , CD with software
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post
    you dont need anything special if you're running windows:
    start->settings->control panel->power options->advanced
    At the bottom of that window, it says "when I push the power butotn on my computer:"
    choose shutdown.
    Now, when you push the power button, it just shuts down--as long as you dont hold the button, then it just cuts off.
    also, make sure your BIOS is set to a delay on power off. My systems all have a 4 sec delay. with these settings all I have to do is push the power button and the system shuts down. if the system locks up, all I have to do is hold the power button down for 5 sec and it cuts power.
    NOTE: this may be hardware dependent
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    Apr 2001
    Post
    What version of windows are you using? I have windows 98 release 2. That's definitly what I need though. How would I get this option if you have the same OS as me? Is there a way to upgrade power options? Thanks.
    -Kev
    Aug 1999
    Upper Marlboro, MD 20772
    Talking
    I believe WinME has it too.
    abcd-1
    May 2001
    Cincinnati, Ohio
    Post
    I dont see that option on WInMe
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Post
    The setting is motherboard/BIOS dependant. Look for a BIOS upgrade. Some older motherboards are sol. You can also hold down your power button and have it shut-off (not windows shutdown).
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Jan 2000
    Alpharetta, GA
    Post
    There should be numerous shareware utilities that let you do this. There is a Windows API call for shutdown. I found one at Download.com Called Shutdown Now.
    JohnRam
