Results 1 to 10 of 17
Thread: How to run another program when Winamp is the Shell?
    Nov 2001
    Melbourne, Australia.
    Question How to run another program when Winamp is the Shell?
    Basically ive got Winamp as the shell, but I want to have a clock on screen aswell. When my system goes back into my car it will replace the head unit, so Ill have no clock.
    Any Ideas??????????
    Anyone know of a simple clock program?
    Apr 2001
    Here, There, Everywhere
    Post
    you can run a btch file from memory as the shell, thus you could load two or more programs from the batch file.... that should solve the problem.
    dont know about good clock proggies.... if I had a need for one I would code it myself in VB6, get the look/feel exactly how I would want it..
    Project - GAME OVER :(
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Post
    Ya, swipe the clock prog from Win3.1. Win95 supports legacy apps, I'd imagine Win98 and other versions do, too.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Nov 2001
    Post
    Ive found the program that I want, but im not too sure about the batch file thingy.
    Oh yeah, Magnetik........did you get my email???????
    Ive got some parts for you
    Nov 2000
    Louisville, Ky
    Post
    I am going to attempt the batch file setup today after I change my sparkplugs in my car. But if you need some info on creating batch files there is somewhat of a tutorial Here.
    Nov 2001
    Post
    Jul 2001
    Richmond, VA USA
    Post
    I am having a problem with this, I am actually trying to do it on my Win2k machine in my house. It works fine except that after it loads the first thing then winamp, the focus is removed from the command screen and it wont exit properly leaving me with the black box still there, is there a command to make it return and exit?
    Note: it isn't a clock I am trying to run.
    Any ideas?
    Josh Karger
    By reading this post you agree to overlook all grammatical, spelling, and typographical errors! ;)
    Sep 2001
    Post
    as I recall, there is a "wait" command... it will run a certain line, and wait for that function to finish, then it will proceed to execute the rest of the batch file.
    it's been soo long that I can't remember how to implement that command, but I bet you could find it somewhere on the net.
    edit: oh wait, that's not what you're asking (it's late).. how about just adding an "exit" line at the end?
    Good luck,
    -Miles
    [ 02-10-2002: Message edited by: milesg ]
    Near Completion: Intel P166 MMX, 32MB ram, 13GB Hard Drive, Keypad, 4x40 LCD. Sproggy MK2.6 ATX PSU. Win98SE with Winamp and Mark Zehnder Plugin. (Web-site: very soon)
    Oct 2001
    NYC
    Post
    have it call winamp last and it will show up topmost. theres no command to close the used command prompt. I use the registry for mine... its somewhere around in here:
    /local machine/software/microsoft/windows/current ver/run/
    Jul 2001
    Richmond, VA USA
    Post
    Well I have an exit at the end of it... and without winamp loading (just oading on program) it does close out and go away, or I found out if winamp is called but already loaded it will go away, otherwise it just sits there. (the used command prompt) I need this to run whenever I click the batch file... so I don't understand how I could use the registry to do that. I couldn't find anything that might help on the web, but I will try again later.
    Josh Karger
