Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: hacking gps datacd
    Jul 2001
    The Netherlands
    Post hacking gps datacd
    Hi all,
    I was wondering if anybody knows off gpssoftware which is easy to hack?
    my problem is: I want movingmap software which is kinda 3d on my tft, but I want it also to output to a lcd showing just me the direction by means of an arrow or something.
    Since I don't think such software exists I want to write it myself, problem is that I need the maps with locations, adresses etc. Also I don't want to write a "from to" algorithm since people much smarter than myself have made something like that.
    So what I basiccaly want is a database with maps, coords en functions which I can access.
    anybody?
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
    Jul 2001
    The Netherlands
    just bumping hoping anybody has any ideas
    Dec 2001
    Paignton, Devon, UK
    Good Luck - I was looking for the same thing until I just gave up on the project
    Something for a better programmer than me!
    Mediabox Hardware Project
    Current Stage: A complete redesign, although not much happening right now!
    Mediabox Software Project
    Status: Writing Sync Software (still) and playing around with interface
    To do: Far too much!
    Aug 1999
    Washington D.C.
    What kind of LCD do you want to display it on? Alphanumeric?
    I have a VB app that without to much tweaking will do what I think you want it to do. I was going to use it to display my direction via a GPS receiver and some engine information (MPG, etc.) via OBD-II and display all that on a little 2x16 or 4x20 alphanumeric LCD.
    The only foreseeable problem with that is that only one program can access the serial port at a time, so it makes it hard to use a commercial GPS program with it.
    Jul 2001
    The Netherlands
    well the arrow wouldn't be a problem, I'm using a graphic lcd 240 x 64. The real problem is I want to outpput to both my lcd as my tft. on my tft I want moving map, on lcd the basics.
    I have a navtech cd from a BMW 328, but it seems the single data file contains multiple ".gz" files I don't know how to "cut" the single datafile into the different files so that I get normal .gz files which can be unpacked. the gz files are compressed ".gdf" files.there is enough information on the web to decode de gdf files but zero on the "multiple zips in one file" problem....
    May 2001
    Toronto, Canada
    Hey ZipLock, mind if I take a look at that VB program? I've been wanting to display GPS info on my char. LCD, this sounds really interesting. You mentioned that the prog will only access one COM at a time - my LCD is serial (matrix orbital), so not sure if this would be a problem.
    Apr 2002
    South Coast, UK
    That would be seriously easy using Mappoint 2002 and VB. The big downside is that the maps are North-up only, you cant rotate it to be heading-up. I was going to use it until I found some decent software to use. Mappoint is expensive, but MS do a 60-day trial version with all the map data.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    May 2002
    Sef'Kylar
    Yeah.. I was hoping that I would be able to output some info like heading longitude and lattitude to my char lcd.
    Too bad mapmaking is an involved and expenisve process or we might have some freeware ap that you could write a plugin for.
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Aug 1999
    Washington D.C.
    It wouldn't have a problem with that. The problem would be if two programs tried to access the same gps on the same serial port at the same time, which isnít possible at this time. Hence my post earlier today, Share GPS
    Aug 1999
    Washington D.C.
    You can get free raw mapping data from the US census. They are called Tiger/line files. I downloaded the 6 or 7 cd's full of data, I have been messing around with it for a long time and I have found it to be very hard without a GIS background. I was trying to get it to work with a program called MapServer, http://mapserver.gis.umn.edu/ so I could make some phat web based maps with GPS data, but I havenít had much luck getting it to work.
