Results 1 to 5 of 5
Thread: WinAmp Playlists & IRman
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Question WinAmp Playlists & IRman
    I've found I can't move winamp play lists in to different folder once I've created them, they can seem to find the tracks.
    The same applies if you copy the playlist and past the new one in a different folder.
    Now in order to use IRmans change playlist function, I need all my play lists in the same folder.
    Any Ideas how I can copy them over without openning each in winamp and going save as.
    Also they all need to be renamed 1 throught 9999, any ideas on how I can do this.
    I was wandering if anyone could help as to do this the long way (ie save as, several hundred times) will take hours
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    Variable Bitrate peter3's Avatar
    Feb 2001
    The Netherlands (deventer)
    Post
    send you a mail hopefuly with solution.
    Peter3
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
    Apr 2000
    Little Rock, Arkansas
    Post
    If I remember correctly, you just create a playlist.lst file (located in the specified directory) and list your playlists as well as location in it. Line 1 would be playlist 1, etc.
    ex.
    c:\mp3\incubus\morningview\incubus-morningview.m3u
    c:\mp3\incubus\science\incubus-science
    you get the general idea. Then you wouldnt have to move the playlists and you also wouldnt have to rename all your playlists to numbers, much simpler. Its discussed in the plugin that comes for irman. Hope this helps, if you havent already found help.
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    Post
    for renameing files, try a program called acdsee... you can select a load of files, right click on rename series.... job done!
    Jun 2000
    Salt Lake City, UT, USA
    Post
    Wow.
    I've been using ACDSee for years and never knew that was there. Thanks for the tip!
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
