Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Need help with MPXF 1.4
    Low Bitrate dapepster's Avatar
    Jul 2001
    Jerome, ID, USA
    Question Need help with MPXF 1.4
    Okay, I got one for ya.
    I just got my machine all gathered together with my ESS 1868 sound card (ISA) loaded in DOS using MPXF 1.4/MPXPlay (on a Pentium 133 socket 7, Intel i430HX chipset). I tried it on the machine I am typing on now (P3-500 MHz), and the whole thing works good, but when I transfered the files to the player machine, it gave me:
    MPXF 1.4 Start
    Error opening MPXF.CFG
    Any idea what this is? It didn't do this on >THIS< machine, but just on my player....
    In case it helps, here's the details of my autoexec.bat file:
    Code:
    C:\AUDIODRV\ESSCFG.EXE /A:220 /I:7 /D:1 /B:330 /J:E
    C:\AUDIODRV\ESSVOL.EXE /V:8 /L:8 /W:8 /M:0 /C:8 /S:8 /A:0
    C:\MPXPLAY\MPXF.EXE
    Config.sys:
    Code:
    DEVICE=C:\AUDIODRV\ES1868.COM /A:168 /I:F
    STACKS=18,256
    Need help!
    [ 10-04-2001: Message edited by: DaPepster ]
    Apr 2001
    NJ
    Post
    Hi DaPepster,
    Make sure that MPXF.CFG is in the correct directory, and that MPXF and MPXPLAY are in the correct directory, and the PATH statement in Autoexec.bat has the correct paths in them.
    Mike
    Jul 2001
    Jerome, ID, USA
    Post
    Okay, I did a little more playing around with this machine, and just for the fun of it, I just ran MPXF.EXE from the C: prompt, and it tried to load, but it said failure in XMS memory. Make sure you have himem.sys in your config.sys file.
    Tried that, and it did the same thing!
    Jul 2001
    Jerome, ID, USA
    Thumbs down
    Can somebody just copy their config files into a .zip file and just email them to me? This is p***ing me off....
    You'd think that for one with a degree from NRI in PC Servicing I'd be able to figure it out, but I guess I'm not that good...
    ::shrugs::
    May 2001
    Conklin, NY
    Post
    i think the reason it can't find the config is because you run mpxf.exe as c:\mpxplay\mpxf.exe, which will cause the app to think the active path is c:\, where your config file clearly is not contained. try changing that line to:
    cd c:\mpxplay
    mpxf.exe
    that should at least fix the config problem. in terms of memory, try copying emm386.exe and himem.sys to the player and make a config.sys file. in this file, put:
    DEVICE=C:\HIMEM.SYS
    DEVICE=C:\EMM386.EXE
    that could take care of that problem as well. good luck.
    Apr 2001
    NJ
    Post
    Hi Nipkick,
    I think you nailed it! I remember having a similar problem at the beginning.
    Mike
    Jul 2001
    Jerome, ID, USA
    Angry
    nipkick: Okay, I got it to load the MPXF frontend without problem, now here's the NEW problem: every time MPXPlay tries to play an MP3, it freezes the computer. I even tried just loading MPXPlay itself and tried to load an MP3, and it still crahses.
    Any ideas...?
    [ 10-06-2001: Message edited by: DaPepster ]
    Nov 1999
    Sydney NSW Australia
    Post
    The problem is you sound card setting most likely. Check the sound mixer (software driver) and change the IRQ/DMA setting and see if that helps.
    I think im using the same sound card in my setup so i know it should working without a problem.
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
    Jul 2001
    Jerome, ID, USA
    Arrow
    Fosgate: Ahhh.....I think yer right, man. I'm looking at the autoexec.bat and I see the ESSCFG.EXE file taking IRQ7, DMA1 (that IS what the /I: and /D: switches mean, right...?).
    The parallel port is set to ECP mode, IRQ7, DMA3. ...I'll change one of these and tell you how it goes....
    Jul 2001
    Jerome, ID, USA
    Angry
    GRRR.....still crashes...
    Here's what my autoexec and config files look like:
    AUTOEXEC.BAT
    Code:
    C:\AUDIODRV\ESSCFG.EXE /A:220 /I:10 /D:1 /B:330 /J:E
    C:\
    cd\
    cd MPXPLAY\
    MPXF.EXE
    CONFIG.SYS
    Code:
    DEVICE=C:\HIMEM.SYS
    STACKS=18,256
    I have the parallel port set to ECP mode with IRQ7 and DMA1.
    Alright, lemme ask this; has anybody else had problems with MPXPlay crashing upon playing a file...?
