Results 11 to 20 of 21
Thread: An embedded NES emulator?
  1. #11
    May 2004
    Denver
    don't most front ends have a three key salute that eject you from the current game?? since you will be playing with a gamepad, etc... what about just looking into remapping non-used buttons on the controller to handle volume, etc??
    I have a few versions of MAME and they all just kick back to the MAME frontend whenever you hit ESC, but on the MAMEoX (XBox) I think it is just Select/Start at the same time and you are back...
  2. #12
    May 2004
    Quote Originally Posted by mgithens
    Not a bad idea to look into
  3. #13
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by tmar89
    Do you have any examples of this in C?
    Humm, I don't have any examples since I haven't made a frontend for an emulator before. However, if you're looking for some code that will find the emulator window and some templates for sending receiving messages to and from then I will gladly whip up some snippets. Just ask.
  4. #14
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    Well emulators like MAME can be accessed using a simply command line like "MAME MSLUG3" which will run Metal Slug 3 without anything else seen, so maybe just a frontend full of these shortcuts?
    CarPC status: iPod, 3,456,217 songs so **** you
  5. #15
    Jul 2004
    All over the world
    But lets say you wanted to have buttons to perform save states and other operations. Ideally the emulator can take parameters for all these actions and tests to make sure only one instance is running at a time. However, most are not written this way.
  6. #16
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Quote Originally Posted by Motoko
    If you guys had seen my post on Dual Screen setup you would see that i had a basic Emulator frontend on the back LCD screen.
    There are MAME versions of snes nes atari 2600 genesis/mega drive etc.
    What i mean is i had these setup and it had the default mame keys so esc quit ALL of the emulators
    U can hack the dat file for zsnes to set esc as the exit key and with genesis you can get a mame button config for esc games.
    All these emulators support sending game info to the emulator
    E.g. zsnes metroid
    Look for emulators for use in MAME cabinets people have hacked these to use esc as the exit button of the emulator
    It's how I had mine setup
    I basiclly made a frontend which looked like the mame32 where a screenshot shows up of the game when you scroll the list.
    Altho i had snes pads controlling the frontend
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  7. #17
    Jun 2003
    Memphis - TN
    Whats a good program that will play mame as well as other system types? I have lots of roms. plus I have a mame arcade. Id like to use them all w/o separate progs.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  8. #18
    Aug 2004
    try Mess
    its a emulator with nes snes mame etc all combined with c64 its got a hell of alot of emulators
    Now take a look at this
    I think this is all you need its a nes emulator called Nestopia
    Embed it into media car or whatever frontend you like
    Nestopia.exe is the file
    *Nestopia* is the search string
    This is a opensource nes emulator made in c++ and if i get time (which i don't think so) i'll try to edit the menu system for more touchscreen friendly
    Also the emulator pauses when you shutdown the GPS window in media car and will start again if you touch the game screen
    pretty good i think
    Hope this helps you a bit?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  9. #19
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    looks awesome,
    thanks for finding this for the whole community
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
  10. #20
    Aug 2004
    I didn't find it i've been embedding nes/snes/etc for a while in my carpc
    You can embed zsnes gens and hell of alot of emulators.
    If i can find some info on embedding windows into a VB app i'll make a small Game launcher where you launch the game for each system and then it embeds the game into the VB app so you only embed the gamelauncher so all the emulators like nes snes etcare run in the 1 window
    I haven't found any info on embedding a app into vb yet
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  1. CoPilot Live 8 Embedded
    By chuckster in forum Centrafuse
    Last Post: 11-10-2005, 01:24 PM
  2. Screen size of IGuidance Embedded in FP
    By PDiddy in forum FrodoPlayer
    Last Post: 02-11-2005, 08:07 PM
  3. Touch screen friendly NES emulator
    By warnockm in forum Software & Software Development
    Last Post: 01-05-2005, 10:39 PM
  4. Which NES emulator to use?
    By tmar89 in forum Software & Software Development
    Last Post: 10-06-2004, 03:56 AM
  5. NES emulator?
    By AlphaFox in forum Software & Software Development
    Last Post: 10-24-2003, 08:05 PM
