Results 1 to 6 of 6
Thread: Dos and the ESS chip
    Sep 1999
    Has anyone gotten a dos mp3 player to work with an ESS soundcard?
    bab
    bab is offline
    Jul 1999
    I have a board w/ the ESS1488 chip on it running my system. The comp. is not yet installed in my car, but it seems to be working fine in dos on the bench. I have some noticeable background static but I think that may be a grounding/sheilding issue.
    Still working the bugs out, but it does work
    pretty well, even on my 486-overdrive. The
    system hovers at about 50-60% cpu usage while playing.
    Sep 1999
    What software are you using?
    bab
    bab is offline
    Jul 1999
    Well, I was using MPXPLAY and <a href="http://amp.mp3car.com">AMP2</a>.
    However, I found out the reason I had so much static. It turns out that the 1488 chip is only 8bit. I couldn't find out any info on the chip and I assumed it was SB16 compat.
    Oh well, so much for using this old system (at least it was free).
    I hope you have one of the ESS16XX or 18XX chips.
    Sep 1999
    I have the 1686 or whatever it is, but i can't get mpxplay to play through it. Can't figure it out...
    bab
    bab is offline
    Jul 1999
    Do you get any error messages?
    Does mpxplay run but no sound?
    How did you configure the sound card?
    I got the sound to work by simply adding
    the SET BLASTER tags in the autoexec.
