Results 1 to 10 of 12
Thread: request
    Aug 1999
    request
    I am looking for a plugin that will let me play my playlist files BACK TO BACK like an endlist track, rather than crossfading into eachother. Like a mixtape or mix cd... endless.
    Aug 1999
    San Marcos, Tx, USA
    can't you just set the loop option in WinAmp?
    Aug 1999
    How do I set the loop function?
    ZyKlon_X
    Guest
    Well loop button is the one next to the shuffle button. They are both next to the keys used for playing the mp3. If u still dont know where it is, If u still cant find it. Ill post a picutre next post.
    Aug 1999
    I am not talking about that function. That does loop the entire playlist, but I dont want any spaces between songs... You know how a mixtape sounds... one continuous mixture of songs? No spaces whatsoever... can anyone write that type of plugin?
    Aug 1999
    San Marcos, Tx, USA
    don't know if this would help you but i built a custom mp3 player file manager type app to be used my car. What it can do is allow you to select and play a variety of mp3's, folders containing mp3's, and m3u's. Theoretically, you could uses this to select the m3u files you wanted played to play them seemlessly. If you're interested you can check it out <a href="http://crv.mp3car.com/mp3player.html">here</a> - however, not sure if it will behave in the way you are looking for.
    Jul 1999
    Decorah, IA, USA
    I'm rather confused by this request.. when I play a playlist in WinAMP, it doesn't ever pause or leave a gap between tracks.. motif, what version of WinAMP are you running and how fast is your computer?
    Aug 1999
    I am using the latest version, I just downloaded it this week. I want the playlist to play through the songs "seemlessly"... so that you cannot tell that another song is starting and one is ending.
    Oct 1999
    I get you right, you want to have player that would play songs mixed to each other in a way that a DJ would.
    You realize that this would be done in a away of altering speed. In this case automatically. You would have to define a BPM (beats per minute) in which every song is being played. If you have very different kinds of music it would sound some sort of a ****.
    For example some 82bpm rap song would sound a bit different when played 132bpm
    Probably the biggest problem is to get those songs to sync. And that my friend, is not easy job to do. Go ahead, try to figure a way to measure bpm from any possible song given. Acappella, Classical, drum 'n bass, just to name a few bit hard ones.
    Though I'm not saying that someone would of not done this kind of a plugin or is willing to construct one...
    -FastLane
    Jul 1999
    Decorah, IA, USA
    Ah! I finally found the plugin! I knew it was out there somewhere.. actually, I think it used to be packaged with WinAMP. Anyhow, it's simply called the "Continuous Output" plugin and can be found at the WinAMP web site on the <a href="http://www.winamp.com/winamp/plug-ins/browseplugins.phtml?cat=7&start=0">general plugins</a> page.
