MusicMatch does that...
Anyone know of a program that will create a playlist for all the mp3s in folders as well as sub folders?
I have all my mp3s split by artist/album. Id like to have a program that creates a playlist based off of artist. Anyone help me out?
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
TruckinMP3
Read the FAQ!
playlist for what software? drag and drop the whole directory tree on the playlist in winamp
I have over 10K songs, I cant just load them all up, Id like to create a playlist for each band, as opposed to every song on 1 PLS.
Why not use a player that keeps a library? This way you don't have to read through directories. This way you do not have to load ID3 tags for every song, everytime. This way you can do quick searching and browsing based on multiple criteria.
Here ya go. The first textbox i the directory of your music. The second if for teh playlist folder. It will make winamp playlists off the directory names of each artist, not ID3 Tags.
Thanks.. but it will not open![]()
weird... do you have .net framework installed? sorry guess i should have said it was vb.net. I figured most pc's have it now anyways. Downloads and runs for me fine.
thanks all it needed!! thanks!
Not a problem. I used it for a while to create playlists for my new front end I am writing.
