Results 1 to 8 of 8
Thread: Windows Millenium - Disable Scandisk?
    Apr 2000
    Post Windows Millenium - Disable Scandisk?
    Hello all,
    I just picked up Windows Millenium for my box. Has anyone been able to shut down the automatic scandisk which runs if Windows is not properly shut down? I set the msdos.sys command to autoscan=0 which does the trick in Win 98, but scandisk continues to run. Thoughts?
    Jun 2000
    Massapequa, New York, USA
    Post
    You can use tweakui to shut down scan disk in Millenium Edition. I have it on an mp3 box in my house. Any questions just ask.
    Jul 2000
    Norway
    Post
    No, there is no need for an external tool.
    Start menu -> Programs -> Accessories -> System Tools -> System information
    From the Tool menu, select System Configuration Utility.
    Press the advanced button, and check "Disable scandisk after bad shutdown".
    Hope this helps.
    Sep 1999
    Yarmouth NS, Canada
    Post
    or... you can just type 'msconfig' in the run dialog off the start button.. bit less clicking for the lazy people (like me).. that gets you the same place as going into the system information tool and running the configuration tool... msconfig lets you disable almost everything running at boot time (all the stuff in the registry) as well.. I disabled everything and it didnt effect my boot up other than making it faster... which is always nice.
    [This message has been edited by Callahan (edited 07-14-2000).]
    MP3 Cavalier - http://www.mp3cavalier.com
    MP3 Grand Prix - http://www.mp3gp.com
    Jul 2000
    Norway
    Post
    Ah.. I was going to write that, but i just couldn't remember the name of the program file.. Thanx!
    Newbie Etho's Avatar
    Jun 2000
    Arnold, Mo. USA
    Post
    Is there a way you can disable scan disk w/o a utility on Win 95?
    Car - 20%
    PC - 80%
    Planning - 90%
    Apr 2000
    Post
    I believe this will work for 95 also. Find msdos.sys and change "autoscan=1" to "autoscan=0". Msdos.sys is usually a hidden file so before looking for the file go to Windows Explorer and choose view/folder options/view/show all files.
    Jun 2000
    Arnold, Mo. USA
    Post
    Thanks Kevin for the advice. Hey where is everybody geting their copy of Win ME??
    Car - 20%
    PC - 80%
    Planning - 90%
