Results 1 to 6 of 6
Thread: MPXPLAY remap
    Dec 1999
    Ilion, Greece
    MPXPLAY remap
    I made by myself a keypad but i have a small problem When i press "1" i have "j"
    2 - ;
    3 - 3
    4 - d
    5 - k
    6 - 2
    7 - s
    8 - f
    9 - 1
    0 - l
    * - a
    Does anyone know how to remap the keypad to work with mpxplay? Thanx!
    Jul 1999
    Atlanta, GA, USA
    Edit the mpxplay.ini file. Look at the other examples, and you shouldn't have too much of a problem assigning the right key. Just make sure you don't assign the same code to 2 different functions, or it won't work. A list of the keycodes are included with mpxplay in a text file.
    Scott
    Dec 1999
    Ilion, Greece
    I look at the *.ini file i fount all the functions exept the number keys.
    Jul 1999
    Atlanta, GA, USA
    I don't believe MPXPlay allows you to do that. Perhaps you can write the author and tell him to include that in the next version.
    Nov 1999
    The .ini file can be edited. Just find the function you want to happen, and set it to the value of whatever the keypad sends.
    So if you want the '6' button to make MPXPlay skip to the next track, find the skipto next track setting in the ini, and set it to happen on whatever signal your keypad sends (2?)
    Dec 1999
    Ilion, Greece
    thank you all of you. I remap the keypad. I don't use the numers us "numbers" but i use the as functions. For example i use the button "1" to go to the previus track the "3" to go to the next track etc. Thanks for another one time
