Results 1 to 10 of 19
Thread: Windows 3.11 ??
    Dec 1999
    Lightbulb Windows 3.11 ??
    Anyone use windows 3.11 with sucess in their mp3 car player? I would think that it would load faster. And scandisk would not be a problem. Any info would be nice
    ~meron
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Post
    I thought about it but decided not to because of the software support. Windows Media Player (the core software in my player...details to follow in a few weeks when the whole thing is completed) is available, but crippled. I couldn't use 32 bit VB to program, which eliminated ActiveX, which is how I control Media Player. Windows 3.1x is also not the best multimedia platform and can be a little unstable (depends on the software). Also, you have the FAT16 limitation, meaning you can't use a drive larger than 2Gigs (2048MB) without having multiple partitions. And at that size FAT16 is very innefficient.
    FLAC Gutter's Avatar
    Dec 1999
    Casina, Italy
    Post
    I thought about using Win3.1 too because I found a StreetAtlas USA CD at Goodwill and thought it'd work great with the LCD. But DOS is still the better choice because it boots faster, it's stable, and it's small. And DOS is extremely easy to program for. Less conflicts and crap to have to worry about.
    Good points about Win 3.1:
    It's multitasking
    More software
    Bad points about Win 3.1:
    MS made it
    FAT16
    Boots slow
    MS made it
    Gutter http://impee3.hypermart.net
    The Impee3 Car Player
    Nov 1999
    Smile
    Um, this may be a surprise to you, but MS made DOS too. (since you seemed to think DOS was a good thing, but MS made stuff isnt =)
    Anyway, I cant think of any Win 3.1 MP3 players programs, or any way to control it that is specificly Win 3.1. So you woud either have to write everything yourself, or boot to win 3.1 but use DOS programs like mpxplay, and for that it woul be better to just use DOS.
    Aug 1999
    Yorba Linda, CA
    Post
    Not that I'm all for using Win3.1, but...
    You can still use FAT32 with Win3.1:
    1) Install the disk drive as the slave in a Win98 system.
    2) Use the FDISK utility and partition the drive as FAT32
    3) Format the disk from Win98 explorer and tell it to copy the system files.
    4) Make a directory called DOS on the new drive and copy everything from c:\windows\command on the Win98 boot drive to the DOS directory you just created.
    5) Switch the new disk to be primary master.
    6) Reboot
    7) Install Win3.1 from floppies or CD.
    Now you have a bootable Win3.1 system with FAT32!
    You can also install a patch for Win3.1 to make it able to run 32-bit apps, it's called WIN32.
    Anyway, I haven't tried actually doing this, but I just wrote this to show that it is _possible_ to use Win3.1 with FAT32 and run 32-bit apps. After all, it does multitask better than DOS and boots a lot faster than Win95/98
    --Jason
    Web site: http://www.m2pc.com
    Yahoo Pager: m2pc123
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    MPC Phase IV - *** PENDING ***
    Dec 1999
    Casina, Italy
    Post
    Has this been done? I think I'll try that out. If I can run 32bit apps, then it should work out great. I can make a VB player that would look a lot better than anything I could write in C.
    Dec 1999
    Casina, Italy
    Post
    I mean C in DOS.
    Gutter
    Dec 1999
    Chicago, IL, USA
    Exclamation
    i think this post should have been put into software discussion...i'm not trying to be an ***, but it is definitely not a hardware related issue
    Jan 2000
    Unhappy
    You can run SOME 32Bit apps in Win 3.1, not all. Exclude any 32Bit app that uses ActiveX, which is most of them nowadays.
    Jan 2000
    Unhappy
    You can't really use VB to make 32bit apps to run in 16bit Windows with Win32s installed. I can't imagine writing the low level code required to decompress an MP3 in VB, so I would assume that you would be using the Media Player COM object or something similar. This can't be done under Win 3.1 even if Win32s are installed as it does not support ActiveX (it does do OLE, which is an older standard similar to ActiveX, but ActiveX is not backward compatible). Use a stripped down version of Win95.
