Results 1 to 7 of 7
Thread: slow bios loading.
    May 2004
    slow bios loading.
    my bios loading time is really slow like 20+sec.i have a epia V1000. and it sit at the screen that said via MAINBOARD for about 20+sec. and then sometimes it go no boot drive found. help me out thanks
    SPEC of system:
    epia v1000
    window xp sp2
    wd40g hd
    no cd rom drive.
    Elsewhere
    More information, please.
    What is your primary boot device? CDROM? HDD? CF card?
    Is the PC in your car? On your desk?
    What sort of power supply is it using?
    Really, man. This is like me asking for help because my engine is making a funny noise.
    It reminds me of when I did phone support for Earthlink. Every call started with "I can't get my email". Never mind that some of these people had dead hard drives, a problem more serious than inability to access email. But that's the only symptom they see.
    We can't help you without details, man.
    How about the Wiki?
    May 2004
    primary boot device is my hdd, pc is in my car, and i'm using a 60watt ps from minibox
    Mar 2004
    California
    Sounds like hard drive or hard drive controller failure to me.
    I have a desktop that has a ton of drives, and bios probes all the hard drives and cd/dvd burners, which slows it down.
    Raid controllers slow it down as well. If you have a raid card, or have onboard raid, disable it if you're not using it, because it'll slow things down dramatically.
    Some drives also degrade over time quite a bit, and when they power on and bios probes them, they are in the middle of a drive head sync, so bios has to wait while it does that before it says "I'm here."
    Try with another hard drive (if you have one).
    Kevin
    Audi A4 Carputer, 80% setup.
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Are not you seeking FDD drive while its not connected?
    FLAC djmickyg's Avatar
    Feb 2004
    heynicecar: Im running the very same stuff as u.. but i got an opus powering it all..
    going into ur bios and try setting it back to the safe settings? see if that works
    were u using hibernation with xp? if so how long did urs take to load?
    May 2004
    Quote Originally Posted by djmickyg
    i'm not using hibernation. ill try to change the setting in my bios when i get a keyboard in there. thanks for everyone input.
  1. 800x480 V8000 BIOS & Driver from VIA GmbH Support
    By ShawJohn in forum LCD/Display
    Last Post: 12-08-2004, 04:02 PM
  2. Who else has had problems with Via M10k Bios v1.16?
    By tom2112 in forum General Hardware Discussion
    Last Post: 11-24-2004, 01:33 PM
  3. Replies: 3
    Last Post: 10-22-2004, 12:09 AM
  4. Winamp slow when loading playlists and 'jumping to file'
    By bayere in forum Software & Software Development
    Last Post: 06-25-2004, 09:37 PM
  5. FV24 slow boot problem
    By Mikesz in forum General Hardware Discussion
    Last Post: 02-24-2002, 10:09 AM
