Results 1 to 10 of 11
Thread: Shell Selector Program
    Feb 2000
    Post Shell Selector Program
    Hrm, I don't know how possible this is, but it would really rock. I know that you can get shell selectors for Win98, but I think it would be really nice to have one built for DOS. Basically my idea is that the thing would load litestep as a shell unless you put in a boot disk. If anyone knows how to do this or of a program that does please let me know. I just hate going into DOS edit and changing everything.
    GR1NCH
    GR1NCH
    grinch@jetcity.com
    Luc
    Luc is offline
    Feb 2000
    Mamer
    Post
    I think that there is this kind of thinks in Dr Dos but as I didn't used it for years...
    Just have a try...
    Luc
    Luc
    Sep 1999
    Kuwait
    Post
    Hey G1nch
    I use a program that didpartitions for me and now when I start my Pc, I get a message asking me I I want to boot
    DOS (Win 2000 Advanced Server)
    Linux (Slackware linux)
    I type in DOS for dos and you get the rest.
    Is this what you are looking for
    Feb 2000
    Post
    No not exactly, that is changing the actual Operating System, I am looking for something that would keep the OS as win98, but change the Shell Extension as set in the system.ini file. On my mp3 machine I have it set to load up winamp as the shell, so that the system loads the fastest, and has the smallest footprint possible. However the problem is that to switch the shell back each time I have to use a bootdisk, go into DOS Edit and change the shell line in the system.ini file. I was hoping that there was a program out there somewhere that would automate this process.
    GR1NCH
    grinch@jetcity.com
    Dec 1999
    Santa Ana, CA 92704
    Post
    Don't know how much this can help you, but I use a program called litespawn. It let's you specify as many shells as you want to choose from when windows boots up. Hope this is somewhat helpful.
    Nov 1999
    Sydney NSW Australia
    Post
    Well mate if you know bit of programing you could write a script/code where when you chose the options say load Explorer or Winamp
    your program could modify the Line Shell =
    to what ever you choice.
    Or even easier replace whole .ini file
    with ones you that you already modified.
    say have few .ini files which have different
    Shell settings
    and then you raplce them acording your needs
    what you think of that ?
    this also can be done using a batch file...
    Fosgate
    Fosgate
    System Comp V3 - In progress.
    Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
    Feb 2000
    Post
    BlackDragon,
    Yes I already know about litespawn, I used it for a while, but am waiting for felonous to release his upcoming kick as litestep theme. I wanted more of a DOS based program, but I suppose it could work.
    Fosgate,
    Could the batch file be programed to run off of a bootdisk? Also do you know where I can learn more about setting up the batch file?
    GR1NCH
    GR1NCH
    grinch@jetcity.com
    Nov 1999
    Sweden
    Lightbulb
    GR1NCH
    It wouldn't be any problems at all to run from a bootdisk.
    Just use the built in [Menuitem] in config.sys and have like 3 or more different entrys and then in autoexec.bat
    This is just a really short example.
    Code:
    config.sys
      [menu]
       menuitem=win98, Windows 98
       menuitem=winamp, Winamp
       menuitem=other, Something else
       menudefault=win98, 30
    [common]
    Standard drivers
    [win98]
    Win98 specifik stuff
    [winamp]
    Winamp stuff
    [other]
    Other ****
    Code:
    autoexec.bat
    @Echo off
    goto %config%
    :win98
    copy c:\windows\system.w98 c:\windows\system.ini
    goto end
    :winamp
    copy c:\windows\system.amp c:\windows\system.ini
    goto end
    :something_else
    copy c:\windows\system.xxx c:\windows\system.ini
    :end
    Don't forget to add
    copy c:\windows\system.org c:\windows\system.ini to your autoexec,bat in the harddrive so you get the default one when you boot with no disk in the a: drive.
    Good luck and tell me if you need any additional help.
    [This message has been edited by markus (edited 03-03-2000).]
    Feb 2000
    Post
    Thanks! This should be help a TON! Once I get a working copy up I'll post it on the net for anyone else interested.
    GR1NCH
    GR1NCH
    grinch@jetcity.com
    Mar 2000
    Talking
    Hey GR1NCH...
    Did you finish trying to make that batch file for executing the different shells?
