Results 1 to 2 of 2
Thread: POLL: Performance: Speed or Memory usage
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    Which would you rather consider, a application that has speed benifits and uses slightly more memory. Or an application that uses the least amount or RAM possible but takes a little longer to load each function.
    Crouching Tiger, Drunken Kitty
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Ram is cheap, but cpu-power and disk-throughput are power consuming and physically big...
    Only problem I can think of is hibernation / resume speed if you'd require really much ram.
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Found someting interesting on E-Bay!!!
    By outragis in forum Classified Archive
    Last Post: 01-23-2006, 08:38 AM
  3. Replies: 2
    Last Post: 03-03-2005, 08:15 AM
  4. Slowest CPU speed for good performance?
    By ck42 in forum General Hardware Discussion
    Last Post: 02-04-2001, 06:39 AM
