Results 1 to 4 of 4
Thread: 2 Questions
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    Question 2 Questions
    1st: How do i disable the "Network Logon" screen when i first start windows?
    2nd: Which LCD plugin for winamp is the best? Is there one that allows you to scroll through your playlist on all four lines? Can I use Lorty's plugin with the IRman plugin for control? Will the freeware version of it suffice? (I am not paying that greedy @#$%$#@ any money, software should be free)
    Thanks.
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Feb 2000
    AZ
    Post
    For network logon id have to say somewhere in network properties there should be a primary network logon.. i think if you just change that to windows logon, then switch the name and dont type in a password then itll automatically load windows without askin for password... i never tried this so anyone else want to take a shot at it??
    99 ram 5.9 turbo
    P4 2.0, MicroATX, Audigy2nx, Monster Cable / Alpine.
    Coming soon: Indash motorized, 5.1, dvdrw, gps, bluetooth, wifi, and more!
    Feb 2000
    hoppers crossing, victoria, australia
    Post
    in network propertys change the login to windows login not network
    then dont have users
    tweekui also has this built into it but it changes reg settings
    pcman
    see i can be helpfull
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Jun 2000
    landing, NJ, USA
    Post
    i think you just need to install the family network login client then select that as your primary client. so when you start up your pc it won't ask you for login screen.
    one way i know for sure is that install the windows logon will disable the logon prompt at start up
    how to do it ?
    right click at your network neighborhood icon, then select properties and then under primary network logon select windows logon.
    if you install client such as microsoft family logon do this
    right click at your network neighborhood icon, then under configuration, click at ADD, there will be a pop up windows, under this windows select CLIENT and click ADD then select MICROSOFT then select MICROSOFT FAMILY LOGON in the rightside window then click ok. then goto NETWORK PRIMARY LOGON, select What ever client you want to start up. then just click ok to restart the pc
