Results 1 to 4 of 4
Thread: Problems loading MPXF via Autoexec.bat
    Jul 2000
    Chicago, IL, US
    Unhappy Problems loading MPXF via Autoexec.bat
    Hey guys...
    I'd like to have MPXFTSR and MPXF start when the computer starts. It seems like this would be a relatively easy operation I think that there's just some simple DOS stuff that I'm not understanding.
    Anyway, when I put c:\test\mpxftsr.exe in my autoexec.bat, the program tries to run, but then it gives me a 'cannot find mpxftsr.cfg' file error. The file is there, and the program works just fine when I start it up manually. The same thing goes for Mpxf, only it has an 'error loading mpxf.cfg' message. What syntax did you guys use to auto-load this stuff?
    Also, I'll try and kill two birds with one stone here ... Just once I've gotten a runtime error crash with mpxf. It was during a 'help-tip scrolling display' (dunno what the official term is) I've got the line 'stacks=20,512' in my config.sys. It hasn't repeated itself, but just in case... Should I try 18,256 instead? Or should I try and adjust some type of LCD output parameter?
    Thanks again!
    -Brian Schreck
    Aug 1999
    Upper Marlboro, MD 20772
    Post
    I think u need to add to the path
    ;c:\test also
    it is telling u that it can't find the configuration file. And make sure the path is before the load command.
    abcd-1
    abcd-1
    Jul 2000
    Orlando, FL
    Post
    I had the same problem with my system. I had to change to the mpxf directory before running the mpxf programs. So, in your case, I would add "cd c:\test" (minus the quotes, of course) before you actually call the mpxftsr. I had my mpxf directory in the path, but it just wouldn't work.
    Jul 2000
    Chicago, IL, US
    Thumbs up
    Thanks SupaDave, worked like a charm.
    -Brian
