Results 1 to 5 of 5
Thread: delfolder.exe
    Low Bitrate VehicrossPC's Avatar
    Nov 2004
    Daytona Beach, Fl
    delfolder.exe
    I don't get it, I've had to delete and re-install XP 3 times now and I can't get rid of this "unable to locate file: c:\windows\systblah\delfolder.exe"
    I've deleted evertyhing concerning it in regedit and now this last time I can't even install windows now.. what gives?
    [------|-] 95% computer... is it ever really done?
    www.vehicross.info for all you VXer's
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    run hijackthis and see whats trying to access it
    does it do this in safemode?
    PC Components:
    My work log
    Newbie wagonerd's Avatar
    Dec 2004
    Northern NY
    msconfig...
    it's probably being started on boot. click start > run > type "msconfig" > "startup" tab and look for an entry that has delfolder.exe listed. take the tick out of the box, reboot, voila.
    good luck!
    Dec 2003
    Surrey, BC, Canada
    what do you mean by "delete and re-install XP"? Are you reformatting the drive? Because if you are then you should not be having any problems on a fresh XP install...
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
