Results 1 to 10 of 17
Thread: True Shuffle Plugin?
    Jul 2000
    Israel
    Question True Shuffle Plugin?
    As many of us noticed,winamp's shuffle mode isn't a true shuffle.It seems like it has some kind of pattern,and it plays songs according to that pattern.If you try to use your player at the same time every day,you will see that songs that you heard yesterday seems like repeating on themselves.Looks like the pattern depends on the clock settings,i.e. time .
    Did anybody make a true shuffle plugin for winamp,or you know where I can get one? I know that some people did that but on their custom players,I need one for the winamp
    Enjoint life!
    Nov 2000
    grandeprairie alberta canada
    Post
    that's good question i've noticed that to and would also be interested in a pluging to solve that problem
    Dec 1999
    Santa Ana, CA 92704
    Post
    You're not going insane 'cause it's happening to lots of us. Would be great if they changed the shuffle or someone made a plugin.
    www.geocities.com/blkdragon6
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    At the risk of sounding like an advertizement...
    The Lorty plugin has a shuffle mode...it is too random because over an extended play time...hours, you can hear some songs more than others.
    That is only a minor complaint.
    As long as it is in shuffle mode, if you hit the next song button (or probably even previous song) it will randomly find a new song.
    The winamp shuffle simply shuffles a playlist and uses the result as a new playlist.
    [This message has been edited by DodgeCummins (edited 12-12-2000).]
    Jul 2000
    Israel
    Post
    Lorty uses winamp's shuffle mode,if you press key on his plugin that enables shuffle mode,you will see the winamp's shuffle indicator turns on
    Enjoint life!
    Aug 1999
    Upper Marlboro, MD 20772
    Smile
    lol....One thing for sure, i will implement one for CobraIII. You would think that winamp will select different song when u u have over 800 mp3's on a playlist! Damn bloody ppl at winamp seems to ignore this problem....so many ppl have been complaining to them.
    abcd-1
    Author of CobraI and CobraII.
    For more information on the COBRA Application's please visit the link. For the latest or updated info on CobraII please click on the link. Get new updated files for CobraII here. ftp://picturesictures@128.8.187.126/d:/newdlls
    You can contact me on AOL instant messenger....nick is Cenwesi
    Webpage comming soon!
    abcd-1
    Mar 2000
    Portland, OR , USA
    Post
    That's the primary reason I wrote mine. My main feature is it has a shuffle mode that will not repeat a single song until it's gone through the entire playlist.
    Cenwesi, you should definitely put this on your request list.
    Oct 2000
    DFW area
    Post
    Okay I stand (or sit) corrected...I guess the Lorty generates a playlist on its own, then shuffles through it, because I don't have any playlists on my machine...
    also it must generate a new playlist everytime it starts...unless that is something winamp does automatically since it finds any new song I dump on the drive.
    May 2000
    Ft Gordon, GA
    Question
    if you want true shuffel why dont you just open your playlist then click the misc button, sort, randomize list. voila. no repeat shuffle
    "if everything is under control, you're not going fast enough!"
    Dec 1999
    Santa Ana, CA 92704
    Post
    Easy answer.
    Because it's not all that easy just to click on the playlist and randomize it. Another problem is that when you want to go through a section, like for instance, my STP section, I don't want to have to go back to resorting it. Long process that sounds a lot easier than it actually is.
