if im not mistaken, WINAMP will do that.
I dont know how, I use RJB
All,
Is there a util that will add ALL of the MP3's times together? It would kinda cool to find out the combined time.
Thanks!
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
Check http://www.planetsourcecode.com for such a utility. If you find one with source code only, let me know and I'll compile an exe for you.
Also, I'm in the process of designing a small mp3 player specifically for use in a car. If I'm not mistaken, it's fairly easy to calculate the a songtime. If so, I'll add this as a feature.
Hope that helps.
$150 special - P233, 32MB, 4GB HDD, Win 98SE, custom software, inverter & stereo RF transmitter (ugh!), Muse sound card, NIC
FYI, Songtime is easy (bitrate*file length), unless the file is Variable Bit rate (VBR). As far as I know there is NO easy way to tell the length of a VBR encoded mp3, other that timing how long it takes to play.., if Im wrong, Id love to know about it so I can code it into my player.
Chainsaw
Originally posted by Jodoveepn:
Check http://www.planetsourcecode.com If I'm not mistaken, it's fairly easy to calculate the a songtime. If so, I'll add this as a feature.
-Jason
mp3it - MP3 Software for Small LCD Screens for use in the car.
and
<A HREF="http://www.mp3mystic.com" TARGET=_blank>
MP3Mystic</A> - a personal MP3 Server software for windows.
In winamp,add all your files to playlist,and then in the bottom line of playlist you will see something like that:"0:00/9:30:35",the second part of it is total time of music - 9 hours 30 minutes 35 seconds.
Enjoint life!
If you use winamp you can get a total of your playtime by: Click the misc button on the bottom, then choose 'misc opts,' on that menu select 'generate HTML playlist.' On the top of that playlist you will find your total # of songs, average playtime, and total playtime, it will also let you know if you have any dead playlist entries (tracks of unknown length) which is helpful in cleaning up a large playlist. Hope that helps![]()
I agree using winamp and the html generator however, make sure you have "read titles on load" selected instead of demand and then do it, otherwise you will get unknown times if winamp didn't see the song.
In other words, make sure there is no hh:mm:ss+ in the time for the songs
(hmm, I was trying to make the + bold but it's not working for some unknown reason)
[This message has been edited by Dragyn (edited 11-11-2000).]
