Results 1 to 10 of 18
Thread: Batch Files
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Batch Files
    I've created 2 batch files.. One to disable and one to enable a device that causes me problems...
    Everytime I want to use this device I have to run the enable batch file and after the usage the disable..
    Is it possible to make the disable batch file run when the welcome screen runs (first thing of all)??
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you can try putting it into the registry under
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run]
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    or if you are running windows 2000 or windows XP, just go to start and run and type in gpedit.msc, and under the Computer configuration and Windows setting hive, there is a place you can add a logon script. which should be fairly early in the logon process.
    肚子笑痛了
    S60 Install
    Jun 2004
    GREECE/Athens
    Thanx a lot for your fast response!!
    I will give it a try!!
    Jun 2004
    GREECE/Athens
    I tried it but I don't know how to write a script that executes a file with parameters!!
    Any help with that?
    Do you know if the shutdown scripts it has is also for hibernate?
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    Put the file in your startup folder
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Here is what I would do. Start-programs-accessories-system tools-scheduled tasks. Then click add task and select the .bat Then tell it to execute on startup.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Maximum Bitrate Mañana's Avatar
    Jul 2004
    Sweden
    otherwise you can create a batch file whitch runs the file you want, with proper parameters, and then tell the program to run that batch file =)
    May 2003
    Miami, FL
    maybe it would help if you could post the contents of your batch file?
    肚子笑痛了
    S60 Install
    Jun 2004
    GREECE/Athens
    @ECHO OFF
    :START
    START C:\DOCUME~1\Anthony\Desktop\devcon\i386\devcon.exe enable *NIC1394
    This enables firewire port... I want it for pcmcia but don't remember the hardware ID right now!!
    I have one batch file for enable and one for disable.. what I want is to disable the device BEFORE everything starts... I mean first thing at the welcome screen... is this possible?
  1. Media Files Synchronization
    By IntellaWorks in forum Software & Software Development
    Last Post: 01-20-2005, 08:37 AM
  2. Corrupted VS.net Files
    By BiohazrD in forum Software & Software Development
    Last Post: 11-23-2004, 04:53 PM
  3. Replies: 2
    Last Post: 09-08-2004, 06:07 PM
  4. After I copy files, they are corrupted.
    By Cliff in forum Software & Software Development
    Last Post: 05-17-2003, 08:49 PM
  5. batch file playlist creation size limit?
    By AndyM in forum Software & Software Development
    Last Post: 08-08-2001, 12:06 AM
