Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 86
Thread: iGLaunch v2 - Routis/iGuidance Nag Remover + More
  1. #61
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by NRGZ28
    Well I'm not using it with any frontend... this is what it does aaaaal by itself
    Hmmm... the next version will be configurable so that you can change how much time it takes to rpess the button.
  2. #62
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by moahdib
    If you add full screen to this it would be perfect...like this
    I am using a separate app called "full screen" by fanix to do that right now.
    I will definately add the full screen feature when I do the skin. Otherwise you won't be able to get out of the fullscreen mode.
    BTW: NaviVoice already has the fullscreen mode.
  3. #63
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    hey 0l33l...when you planning on releasing the new iguidance skin? (touchscreen friendly version?) at the same time, maybe you can work with guino to get it embedded in Road Runner! im definately happy to hear that iguidance is getting more attention now in terms of skinning, cause Map Monkey is not doin it for me (directions suck and maps are crappy here in the US)
    on another note, am i gonna see ya at the carpc meet in buena park?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  4. #64
    Oct 2004
    San Diego, CA
    oh... are you going to make the POI's easier to find and make that darn OSK much larger? if this interface can can be as good (or better) as schnoids toyota navi software, i can probably convince him to switch over to a carpc!
  5. #65
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Sounds awesome ol33l, can't wait to see what you do with this puppy!!
  6. #66
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Chita79
    Well, I haven't really started on it. Istead of embedding iGudiance, you will be embedding my little app, which will have iG embedded in it without the titlebars, etc...
    I'm doing this to keep iG competative
    Yeh, I should be at the buena park meet if its at the right time, and if the fords keep away
    The POIs are a problem. I can't do **** about the tiny font that iG uses. If I resize that form, then I just get a bigger form
    Yes, this will include an OSK from MediaCruiser... yes... parts his code is going to be used
    The interface is going to be skinnable... so I'll leave that to the user's imaginations
    Quote Originally Posted by tj!2k4
    Jul 2004
    Berkeley, CA
    I'll be using the SDK from MediaCruiser
  8. #68
    Jul 2004
    Berkeley, CA
    Talking Teaser
    Just with a few min of testing
  9. #69
    Oct 2004
    San Diego, CA
    will u be able to do anything about the menu and volume buttons on the bottom left?
  10. #70
    Oct 2004
    ..also, the speed indicator..?
  1. iGLaunch - Routis/iGuidance Nag Remover
    By 0l33l in forum Software & Software Development
    Last Post: 04-04-2005, 02:20 AM
