Page 9 of 9 FirstFirst 123456789
Results 81 to 86 of 86
Thread: iGLaunch v2 - Routis/iGuidance Nag Remover + More
  1. #81
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Lightbulb Check out v3
  2. #82
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    how about iGuidance embedded in RR buddy?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  3. #83
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Chita79
    Change the settings in RR to capture a window called iGLaunch. Post in the other thread
  4. #84
    May 2005
    Quote Originally Posted by 0l33l
    Future of iGLaunch:
    Soon, iGLaunch will be phased out. To be replaced by something better
    A Skinner for iG. Bigger buttons. The program will embed iG into itself and remove the title bar and all other bars from iG. Then it will place a button ontop of the menu button we currently have. When you click on the button, and a menu pops up, but this menu is skinnable. Then you will be able to do everything you could with iG, except with much larger buttons. So you'll get a prettier interface, more usable, and more screen real estate
    This will be the primary interface I use for iG. It will run on the FrodoComm network.
    hi i think you are a GENIOUS !!!!!!!! is it possible for you to send me some sort of a file that will replace original one so it changes all the fonts and icons.???
    thanks
  5. #85
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by akberpaf
    thanks
    Take a look at Ol33l's signature and read up on SkinBedder.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
  6. #86
    Jul 2004
    Berkeley, CA
    thanks
    Search for theme.ini and theme2.ini and ctheme.ini. It all depends on which version of iG you're using.
  1. iGLaunch - Routis/iGuidance Nag Remover
    By 0l33l in forum Software & Software Development
    Last Post: 04-04-2005, 01:20 AM
