Page 1 of 9 123456789 LastLast
Results 1 to 10 of 86
Thread: iGLaunch v2 - Routis/iGuidance Nag Remover + More
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Configurable Routs/iGuidance Nag Screen remover. This works with centrafuse. No multiple instances of iGuidance or Routis. This also resumes the GPS if the computer resumes from hibernation. Comments, suggestions, etc welcome
    Code:
    Version History
    [v2]
    *New Features*
    -Reconnect GPS on resume
    	Will click on the COMM port after coming out or Resume
    *How To*
    -iGLauncher.ini
    	FILENAME - Self-explanatory
    	DIRECTORY - Self-explanatory
    	PARAMETERS - Self-explanatory
    	COMMPORT - The COMM port that the GPS is on for Resume
    	RECONNECTGPS - TRUE or FALSE
    Download v2
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    Gonna try this out as soon as I get back to the car!
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by gizak
    It works out great on paper, just hope it works in the car
    Also, I'm not sure if you have to have the GPS app be visible before hibernation.
    Jul 2004
    Berkeley, CA
    Anyone get it working?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Port it over to Frodo and I will
    Sound Stage
    Eclipse|MTX|Infinity
    Feb 2004
    Phoenix, AZ
    I gave this a shot since the other solution was in fact opening multiple instances of iguidance when used in CF. I thought this was working fine at first, but realized later that it wasn't. Maybe I'm doing something wrong... Also, I'm not a coder, so wasn't sure what to put in the parameters field (i guess it isn't self-explanatary to noobs lol). Also, I don't think it matters, but I'm using a BT GPS unit.
    -GiZak-
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by -zip-
    What do you mean? You can use with with FP. Just change the filename to my program.
    Don't put anything in the PARAMETERS field. Also after installing it and configuring it to workin CF, restart CF. Don't forget to set the window caption to "iGuidance".
    Feb 2004
    Phoenix, AZ
    Quote Originally Posted by 0l33l
    Yea, I left PARAMETERS blank, and I assume you mean to put the window caption in CF to "iGuidance" , which I did. It was really weird, I'll tinker around with it some more, cause I could have sworn it was working when I first used it, but anytime thereafter, the nag screen popped and stayed.
    -GiZak-
    Jul 2004
    Berkeley, CA
    Restart CF. Also check if either applications is running. Just do a full shutdown
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    How does this work with RR?
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
  1. iGLaunch - Routis/iGuidance Nag Remover
    By 0l33l in forum Software & Software Development
    Last Post: 04-04-2005, 02:20 AM
