If it is an executable (.exe) just right click on it, click the Compatibility tab and check the compatibility mode. I'm pretty sure this only works for executables though, not sure if it will work on an installer.
I have a scansoft scanner that was designed for Win 95. I am trying to put it with my Win XP and run the scanner. However, I cannot run the install disc in XP because I keep receiving a compatability error message. I was told there is a way to change compatability settings for your computer to allow older software to run. I would appreciate anyone's help assisting me in finding the setting in XP to change compatability.
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
I have had to change the compatibility on the setup.exe,
run the setup.exe - find were its extracted the temp files, to run setup,
and change the compatibility on the install.exe and any .EXE
in that dir - this dir might be in
C:\WINDOWS\temp
or
C:\Documents and Settings\---"your user name"---\Local Settings\Temp
and then let setup finish, if you exit setup the files will be deleted
check their website for updated drivers, most of the time they won't work with that compatibility option.
