Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: What programming language?
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Hi everyone. I've been a programmer for a few years, as a hobby. I mostly do PERL, and I'm pretty good with it. I'm not too good with OOP. I've learned some C++ in school. I learned some C++ out of school. I am proficient with C++, even though I use my book when programming with it. Also, anything I've needed to do in C++, I can do in Perl twice as fast, so I don't have alot of practice with it.
    So my question is: What language should I learn? I want one that is robust enough to do low-level programming (IE parallel port), and still have easy to use GUI. I heard VB is good, but I've also heard it's like selling your sould to bill gates. :-/
    Any thoughts?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Awesome VB replacement: Delphi. No need to use MS products
    And yes, you can do parallel port programming, and ASM code if you want. Also a great interface IMO
    Delphi is basically object pascal
    What I don't like about it: for every delphi example, there are like 20x VB examples
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Personally, I would say stick with C++. Sounds like you've already got your foot in the door, and it will complement your PERL knowledge nicely (as their problem domains don't overlap all that much). C/C++ is in extremely widespread use, so even if you don't consider it your 'language of choice' it is a good one to know, and it will handle any low-level task you ever want to do with it.
    That said, for GUIs it's only as good as the library you use (and most are pretty clunky). .NET (managed C++) does it pretty well (for Windows, of course), but then you're back to selling your soul to gates .
    That's my $0.02 anyway. I'm sure others will differ.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by mushin
    Please stay awy from .NET!!!
    Its slow
    Aug 2004
    SE Michigan
    Quote Originally Posted by 0l33l
    Its slow
    I find loading in the debugger to be inexplicably slow, but otherwise I wouldn't say it's particularly slow. I believe there are some objective benchmarks you could check out. I'm hardly a fan of Microsoft, but they did alot of things right in .NET (except for the stupid name...) They don't employ a huge pile of top language gurus for nothing.
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    That, and you can always run ngen on your .NET executable. Good thing v2.0 and 64-bit support will probably be out by the time I set up my carputer
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
    Jul 2004
    Berkeley, CA
    Look at Centrafuse. Even after rewriting all the skin code with win32 API, people are still compaining that its slow!
    You can port Delphi application to linux using Kylix
    Apr 2005
    Seattle
    Let me guess, it's because 90% of carputers are underpowered?
    ...and increase your user base by a whole lot of two linux carputer users out there
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by lastberserker
    Exactly why I'm not building a VIA machine But really, the language is slow, just download a copy of CF for yourself. Even VB is faster
    Hey, some people use linux
    Apr 2005
    Seattle
    Oh, I will. Now that I have my setup running on a desk (wow, those MiniATX boards are tiny!), I'm going to try all popular software (and some hardware as well) to see what I want to keep
    Still, CF being slow doesn't mean .NET is slow - I saw a few nice C#/.NET applications that run like champs. And I'd rather through more CPU/memory than my spare time at apps I code
  1. Replies: 44
    Last Post: 05-22-2009, 02:51 PM
  2. Wanting to learn some programming, help me pick a language!
    By RS3RS in forum Software & Software Development
    Last Post: 10-15-2004, 05:38 PM
  3. C++: GUI Programming with >NET Framework
    By [iG] in forum Software & Software Development
    Last Post: 05-24-2004, 07:57 PM
  4. What Prog. Language for Programs?
    By dug1967 in forum Software & Software Development
    Last Post: 02-12-2004, 12:27 AM
  5. programming language for beginners???
    By DJ in forum Software & Software Development
    Last Post: 09-08-2000, 10:36 AM
