Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 146
Thread: VisualDesigner for creating other skins
  1. #31
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by 0l33l
    Another 3 properties in the background image for the mousedown, on, and on_mousedown.
    You don't get it, do you?
    Skinning to go... VisualDesigner2!
  2. #32
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    i meant glos and clicked for standard buttons... when not using custom draw.... but ok... The click would be a normal up button on the "Normal" and a down button on the "on".... but I'll see if I can get a dummy png for te buttons that looks nicer...
    about the glow, I tried doing that with customdraw, but it doesnt work, because GLOW is usually outside the button, and customdraw doesnt allow the "glow"on the outside of the button... it will only show the button itself, the glow is cropped...
    i'll stop with the ideas and go to sleep now!
  3. #33
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by zorro
    I guess not
    I think I know what you're getting at. Change the image in the skinning section. But what if the designer already has all the buttons on the form, and needs to define hotspots for them?
    This is what I get when I put the selected image under the property of the button.
  4. #34
    Mar 2004
    Munich, Germany
    You think?
  5. #35
    Mar 2004
    Munich, Germany
    I guess not
    This doesn't make any sense (even if you could do that) because no one's be able to change size, positions or whatever of the buttons. and that's the reason why skinning becomes very hard.
    To make a button invisible, set it to CustomDrawn, don't appl images delete the caption and you have it.
    BTW: Read the PDF.
  6. #36
    São Paulo, Brazil
    I think what ol33l wants to do is use VD to make the ini for a background image that he already has....
    Maybe you can make a button and set full transparency?
    EDIT: will other types of fields be supported to allow for different functions of specific frontends? Sliders, touchwheels, lists, etc?
  7. #37
    Mar 2004
    Munich, Germany
    Quote Originally Posted by RoyN
    Look above
    This is part of the ExportProvider.
  8. #38
    Jul 2004
    Berkeley, CA
    BTW: Read the PDF.
    Ok.. I read the PDF. Before I skimmed it.
    RonN phrases my request properly: "I think what ol33l wants to do is use VD to make the ini for a background image that he already has....".
  9. #39
    São Paulo, Brazil
    ol33l did you try setting full transparency? make a button with no text and set transparency and clickedtransparency or whatever the second one is to 0... maybe that will work....
  10. #40
    São Paulo, Brazil
    Look above
    But everything needs to be drawn as a button in VD?
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Replies: 4
    Last Post: 01-21-2005, 09:21 PM
  3. Replies: 3
    Last Post: 12-02-2004, 02:02 AM
  4. Sigh...wish skins worked.
    By Carter in forum FrodoPlayer
    Last Post: 09-20-2004, 03:32 PM
  5. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 06:34 PM
