Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 41 to 50 of 146
Thread: VisualDesigner for creating other skins
  1. #41
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by RoyN
    ol33l did you try setting full transparency? make a button with no text and set transparency and clickedtransparency or whatever the second one is to 0... maybe that will work....
    Yes! But then I have to set the same images for ALL of the buttons/etc. And won't they be invisible also?
    Like try this. As you can see it generates a transparent highlighted button...
  2. #42
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Sorry I dont understand the last question boris....
    from what I understand you have a background image that already has all the buttons (this would pose a problem for the clicked state though, cause the background is constant) and what you want is merely to designate a "hotspot" on top of the background (aligned to a button printed on the BG) that when clicked will perform some action, right?
    If that is the case I dont understand the previous question....
    If that isnt the case then we are all speaking different languages... (Z: german, B: russian Me: portuguese) and hence we will never understand each other until we all switch to english...
    I need to get to bed, its 5fcking30am....
  3. #43
    Jul 2004
    Berkeley, CA
    I'm speaking english
    Yes! I need a hotspot with the exact description you're giving! Because it takes forever to cut out each button in photoshop and then import it.
  4. #44
    São Paulo, Brazil
    try this... I just tried it and it gave me a transparent button... nothing, just the hotspot....
    add a button
    delete caption
    set CustomDraw = True
    DO NOT ADD ANY IMAGES... the lack of images will make the button fully transparent.
  5. #45
    Jul 2004
    Berkeley, CA
    add a button
    delete caption
    Yes, but now the clicked and focused image is transparent.
  6. #46
    São Paulo, Brazil
    ohh, well the quick answer is the way that zorro did this I think is to make it easier to make NEW skins... unless you chop all the pieces up in photoshop I dont think youll be able to make it pull them like it does in RRSkinEditor for example...
    Unless you use VD only for making the INI and use your original JPGs/PNGs....
  7. #47
    Jul 2004
    Berkeley, CA
    That is exactly why I am asking for those changes. This program is very easy to use. And I'm pretty sure that I'll be able to glue together the COM object in VB6 to export it to my XML.
  8. #48
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Update available! (Copy'n'Paste added and some changes on handling).
    Here some screenshots how VD it's meant to be used (hijacked PSD file from this thread: http://www.mp3car.com/vbulletin/show...14&postcount=1 - btbe, please forgive me )
    The original (not complete) mounted on the brushed aluminum:
    Then, background changed to brushed metall with one click:
    Note that all texts shown here are properties of each button. Changing them is done with keying in the new Caption and do a skin export.
    Skinning to go... VisualDesigner2!
  9. #49
    Jul 2004
    Berkeley, CA
    Any updates on my request?
  10. #50
    Mar 2004
    Munich, Germany
    No. My intension was not to make an Hotspot-Editor.
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Replies: 4
    Last Post: 01-21-2005, 09:21 PM
  3. Replies: 3
    Last Post: 12-02-2004, 02:02 AM
  4. Sigh...wish skins worked.
    By Carter in forum FrodoPlayer
    Last Post: 09-20-2004, 03:32 PM
  5. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 06:34 PM
