Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 51 to 60 of 146
Thread: VisualDesigner for creating other skins
  1. #51
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by zorro
    No. My intension was not to make an Hotspot-Editor.
    Oh, ok
    What's going to be the licence for it?
  2. #52
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Freeware. But it sill will be packaged with the PhoCo Setup.
    Skinning to go... VisualDesigner2!
  3. #53
    Jul 2004
    Berkeley, CA
    Ok, sounds cool
    I think I figured out how to make it a "hotspot-editor": define everything with the VD and then replace the images with the originals.
  4. #54
    Mar 2004
    Munich, Germany
    Now you got it
    Anyway, you should consider to use the (original) underlying PSD files instead. This approach is much more flexible.
  5. #55
    Jul 2004
    Berkeley, CA
    Now you got it
    Sweet
    Yeh, the PSDs are more flexibile -- if you have them
    Now I just have to figure out XML syntax in VB6 and interface it with the COM object. Shouldn't be that hard because there's tons of VB examples of XML.
    Thanks for making the program BTW
  6. #56
    Mar 2004
    Munich, Germany
    They're on feb's webite.
    There is no XML passed to the Export-Provider, only plain text.
  7. #57
    Jul 2004
    Berkeley, CA
    I know about the skins. They were used as my example when I tried to write my own skin maker a few months back
    I know that only plain text is passed. I had a quick look into the export-provider. I guess I should have said "many XML examples for saving"
  8. #58
    Mar 2004
    Munich, Germany
    You don't need to bother the Export-Provider to get XML. Simply use the XML file VD stores when saving the design and extract the data you need.
    BTW: You can make the Export-Provider in Delphi as well. Just make a COM-DLL with exporting the 3 methods shown in the VB sample.
  9. #59
    Jul 2004
    Berkeley, CA
    I don't need a lot of the things in the VD XML. I'd rather make it easier to modify by hand.
    Funny thing is that I don't know how to do "layered" XML code just yet in Delphi. And since you have the VB example already, I might as well add the XML code I find to it instead of starting from scratch. Plus, its not like my app will depend on the efficiency of the Export-Provider
  10. #60
    Mar 2004
    Munich, Germany
    Update
    Have added a Slider control, which is nothing other than a Panel except the slider itself (handle) won't be drawn onto the exported bitmaps.
    Also the handling got beefed up a bit.
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Replies: 4
    Last Post: 01-21-2005, 09:21 PM
  3. Replies: 3
    Last Post: 12-02-2004, 02:02 AM
  4. Sigh...wish skins worked.
    By Carter in forum FrodoPlayer
    Last Post: 09-20-2004, 03:32 PM
  5. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 06:34 PM
