Page 7 of 15 FirstFirst 123456789101112131415 LastLast
Results 61 to 70 of 146
Thread: VisualDesigner for creating other skins
  1. #61
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Update!
    Now with FrodoPlayer Export-Provider
    Other improvements:
    - Copy 'n Paste de-buged
    - CustomDrawn controls surrounded with border as long as no images are set
    - AdditionalInfo property added to Background
    Skinning to go... VisualDesigner2!
  2. #62
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Great - now I have no excuse for making my own skins . Zorro, this is truly fantastic - thanks so much for doing this.
  3. #63
    Mar 2004
    Munich, Germany
    Skin on Garth
  4. #64
    Mar 2004
    Munich, Germany
    Forgot to put the link for the Skin.xml (which contains all elements to generate a skin.ini - the main skin of FP). Here it's: Skin.zip
    And please don't forget to register VDFrodoPlayer.dll (with regsvr32 VDFrodoPlayer.dll) .
  5. #65
    Mar 2004
    Munich, Germany
    Here's a short instruction what you gotta do to get this VD version:
    • Download and install the latest version of PhoneControl.NET if you didn't already (it's because there isn't a separate installer for VD available)
    • Get the VD Update here http://phoco.net/tmp/__Bin/VDesigner.zip and copy it over the installed files.
    • Unpack at least the FrodoPlayer or RoadRunner Export Provider and register the DLL with regsvr32 VDFrodoPLayer.dll / VDRoadRunner.dll (see post above)
    Don't forget appliying the -Other{=FrodoPlayer/RoadRunner} option in the CommandLine to make a new skin other than for PhoneControl.NET.
  6. #66
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Got the export-provider code to work
    Instead of going through "real" xml code, I'm just replacing the syntax of the ini
  7. #67
    Mar 2004
    Munich, Germany
    erm... I had to change the Providers Interace for Initalize... now there is one additional array containing some user settings.
    Please dowlnload the latest version and have a look... it's not complicated just the binary compatibility broke up.
  8. #68
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by zorro
    Well, I'm using the latest one, I think. The one that had the Frodo export code. That's the one I'm modifying.
  9. #69
    Jul 2004
    Berkeley, CA
    Something quick I whipped up...
    Attached Files Attached Files
  10. #70
    Mar 2004
    Munich, Germany
    Well done, son.
    Two things you have to care for:
    1. Rename the FrodoPlayer Class to FrodoPlayerXML. Because these are COM objects that'll be address through their ProgId, you would cause malfunctions on computers with both Providers installed.
    2. Also, if the output is another, rename the output file to something like "xx.ini.xml"
    <edit>
    You forgot to place a sourrounding root tag enclosing all other tags. Without your XML code will fail when loading in a DOM.
    </edit>
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Replies: 4
    Last Post: 01-21-2005, 09:21 PM
  3. Replies: 3
    Last Post: 12-02-2004, 02:02 AM
  4. Sigh...wish skins worked.
    By Carter in forum FrodoPlayer
    Last Post: 09-20-2004, 03:32 PM
  5. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 06:34 PM
