Page 8 of 15 FirstFirst 123456789101112131415 LastLast
Results 71 to 80 of 146
Thread: VisualDesigner for creating other skins
  1. #71
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by zorro
    Well done, son.
    Two things you have to care for:
    1. Rename the FrodoPlayer Class to FrodoPlayerXML. Because these are COM objects that'll be address through their ProgId, you would cause malfunctions on computers with both Providers installed.
    2. Also, if the output is another, rename the output file to something like "xx.ini.xml"
    <edit>
    You forgot to place a sourrounding root tag enclosing all other tags. Without your XML code will fail when loading in a DOM.
    </edit>
    Thanks for the comments
    1. Can't figure out how to do this Every time I change the name, it breaks compatability or something.
    2. I like it in the ini format because it opens faster... i'll change it to xml later
    Fixed the root tag
    This is like the 10th time I've used VB from 00'
    Attached Files Attached Files
  2. #72
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    It's ok to break the compatibilty when you create a new object.
    Breaking the compatibilty means VB creates a new GUID for this object. The only problem with that is, each time you break it, the user has to re-register the component.
    So, this is the reason why you usually set the compatibility to the DLL once it's created.
    Skinning to go... VisualDesigner2!
  3. #73
    Mar 2004
    Munich, Germany
    Update!
    This time:
    - Auto sensing loaded skin and mode switch
    - Mode switch possible after start in Tools menu
    - RoadRunner Export Provider included see (pic)
    The XML file for this test skin is here: http://phoco.net/tmp/__Bin/BFM12day.zip
  4. #74
    Jul 2004
    Berkeley, CA
    Oh, ok. Hopefully this works later on tonight
  5. #75
    Mar 2004
    Munich, Germany
    Slight update for RR ExportProvider:
    http://phoco.net/tmp/__Bin/RoadRunner.zip
  6. #76
    Mar 2004
    Munich, Germany
    Update
    - Locked controls are better visualized now.
    - Transparent color can be applied to controls now (only the frame will be drawn).
  7. #77
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    what the hell???/
    I spent so much time working on a skin, then closed the deisginer to apply the road runner update, tried to open the xml file i was working on and i get an
    Error during load saying "0 is not a valid value for EMSIZE"
  8. #78
    Mar 2004
    Munich, Germany
    Don't panic. Open the XML file with an editor, replace the very first and the very last tag (which says <PhoneControL>) with <RoadRunner>, save it and get the latest update from VD, so this ain't gonna happen anymore.
    <edit>
    Just for the record: If you're doing a new skin from the scratch, you have to start VD by using the -Other=xxx option, whereas xxx is gonna be the name of the root tag (i.e: RoadRunner).
    This you'll see in the status line on the right side of the latest version.
    I'm gonna improve this somwhow in the next update.
    </edit>
  9. #79
    Mar 2004
    Munich, Germany
    No comments?
  10. #80
    Maximum Bitrate netsuo's Avatar
    Jan 2003
    Switzerland
    Yes, if you want.
    How are u ?
    NS - neocar suite
    http://www.neocarmediacenter.com
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Replies: 4
    Last Post: 01-21-2005, 09:21 PM
  3. Replies: 3
    Last Post: 12-02-2004, 02:02 AM
  4. Sigh...wish skins worked.
    By Carter in forum FrodoPlayer
    Last Post: 09-20-2004, 03:32 PM
  5. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 06:34 PM
