Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 146
Thread: VisualDesigner for creating other skins
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Hi folks,
    I've added some code to (PhoCo's) VisualDesigner to make it a bit more versatile.
    By applying the command line parameter -Other=xxx users are now able to create a new design from scratch by adding controls (Buttons, Panels, Listboxes) and export that new design to any format needed.
    The export constsist of two major functions:
    1. All elements on the main form will be merged with the background and saved as two bitmaps (Jpeg or Png), one for the normal state and one for the clicked state.
    2. A Export-Provider is called (using COM) and all elements contained on the form will be reported to the Export-Provider. The provider is responsible to create a customized INI file that can be used with any other application.
    Since the design is not only exported but also saved in a VD format (XML), designers are able to reload the skin and apply changes whenever needed very quickly.
    At this stage, there is only one sample Export-Provider which doesn't really do anything but shows how to use it.
    Developers who are interessted in making Export-Providers for their apps, please let me know.
    Designers can use is to create / edit skins for any app but they have to wait for Export-Providers to become available.
    Here's a short instruction what you gotta do to get this VD version:
    • Download and install the latest version of PhoneControl.NET if you didn't already (VD is a part of it)
    Skinning to go... VisualDesigner2!
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Looks awesome! But can we also get a permanent clicked state? So say if we're having relays that are on, you don't want the button to turn to the original state. Then that would require 2 more images
    This would be a great way to create "universal" skins
    Mar 2004
    Munich, Germany
    What is the difference between a clicked state and a permanent clicked state (seen from the graphics side)?
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by zorro
    Well, say that you have an "LED" on one of the buttons to know if a relay is on.
    Mar 2004
    Munich, Germany
    Well... think about... I'm sure you'll find the answer.
    Jul 2004
    Berkeley, CA
    Hopefully
    This project would really help me. My skin designer suxed.
    BTW: Exporting to INI won't be required.. right?
    Mar 2004
    Munich, Germany
    No, this is just a suggestion. Whatever the Export-Provider does, this is up to you.
    Jul 2004
    Berkeley, CA
    Great! Can't wait to test it
    My email
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Seems pretty cool. So, if I understand correctly, you can use this to export skins to any other program, and then simply use the exported file in another program? I would love to try it out, I've been looking at some way to do this, as opposed to using a skinner made to work with one program, and then going back to edit the whole file to work for mine.
    My email.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Jul 2004
    Berkeley, CA
    Some suggestions:
    Have create buttons/listboxes/etc on a toolbar.
    I didn't really find a setting for a "selected" image. Some designers use just 2 images, and create "hotspots" on the forums. I'm guessing that a panel can act as a hotspot.
    The scale mode also doesn't work, just as you said:
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentException: Invalid parameter used.
       at System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
       at System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
       at System.Drawing.Bitmap..ctor(Image original, Int32 width, Int32 height)
       at System.Drawing.Bitmap..ctor(Image original, Size newSize)
       at PhoneCtlDesigner.frmMain.pnlWindow_Resize(Object sender, EventArgs e)
       at System.Windows.Forms.Control.OnResize(EventArgs e)
       at System.Windows.Forms.Panel.OnResize(EventArgs eventargs)
       at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
       at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
       at System.Windows.Forms.Control.UpdateBounds()
       at System.Windows.Forms.Control.WmMove(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 1.0.5000.0
        Win32 Version: 1.1.4322.2032
        CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    PhoneCtlDesigner
        Assembly Version: 1.1.1939.40187
        Win32 Version: 1.1.1939.40187
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/PhoneCtlDesigner.exe
        CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
        CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
        CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Infragistics.Win.UltraWinToolbars.v3.1
        Assembly Version: 3.1.20041.15
        Win32 Version: 3.1.20041.15
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.UltraWinToolbars.v3.1.DLL
    Infragistics.Shared.v3.1
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
    Infragistics.Win.v3.1
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.v3.1.DLL
    Infragistics.Win.UltraWinDock.v3.1
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Infragistics.Win.UltraWinDock.v3.1.DLL
    Accessibility
        Win32 Version: 1.1.4322.573
        CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Design
        CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    System.Runtime.Serialization.Formatters.Soap
        CodeBase: file:///c:/windows/assembly/gac/system.runtime.serialization.formatters.soap/1.0.5000.0__b03f5f7f11d50a3a/system.runtime.serialization.formatters.soap.dll
    System.Xml
        CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    zyg9noqk
        Assembly Version: 0.0.0.0
    zControls
        Assembly Version: 1.0.1939.35709
        Win32 Version: 1.0.1939.35709
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/zControls.DLL
    Microsoft.DirectX.DirectSound
        Assembly Version: 1.0.1901.0
        Win32 Version: 5.3.0000001.1126 built by: DIRECTX
        CodeBase: file:///C:/Program%20Files/PhoneControl.NET/Microsoft.DirectX.DirectSound.DLL
    System.Drawing.Design
        CodeBase: file:///c:/windows/assembly/gac/system.drawing.design/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.design.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Replies: 4
    Last Post: 01-21-2005, 09:21 PM
  3. Replies: 3
    Last Post: 12-02-2004, 02:02 AM
  4. Sigh...wish skins worked.
    By Carter in forum FrodoPlayer
    Last Post: 09-20-2004, 03:32 PM
  5. Skins for 8" Lilliput
    By Deepgear in forum MediaCar
    Last Post: 08-08-2004, 06:34 PM
