Results 1 to 4 of 4
Thread: Jogwheel OSK Tool, but I'm stuck!
    Constant Bitrate ruairi's Avatar
    Jan 2005
    Spain
    I'm writing a small APP to replace the OSKs with a AUDI type jog wheel using the mouse scroller and left/right keys.
    Here's what I've done so farhttp://www.rutlands.com/MouseKeyboard.exe
    THe problem I have is sending the resulting text to the window below. I'm using VB.Net but there does not seem to be an easy way to do it.
    If I get it working I'll skin it and make the letters configuratble for international characters.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    link dosent work
    Super Moderator xBrady's Avatar
    USA
    A quick (crappy) solution is to use the sendkey command to send an alt+tab and then the key you want.
    To get it to work the right way you have to get it so your app doesn't take focus.
    Installed.
    -GPSSecure- - GPS Tracking
    Jan 2005
    Spain
    @liquid_smoke
    The link works for me, it maybe your firewall or SP2 that is blocking it because ir's an .exe file. Right click and try "Save Target As...". Also it needs the .Net engine to run.
    @xBrady
    I tried the alt-tab sendkey but I think XP is blocking it, MSDN says they block it to keep Windows more consistent for users. I've seen some low level WIN32 tricks but I'd prefer to do it in managed code. I'll have a look at focus.
  1. OSK... need help/ideas..
    By guino in forum Road Runner
    Last Post: 06-25-2006, 08:49 PM
  2. OSK and iguidance
    By kuo in forum Road Runner
    Last Post: 07-19-2005, 07:31 PM
  3. OSK bug ????
    By tolisn in forum RR Bug Tracker
    Last Post: 03-31-2005, 12:25 PM
  4. Dual OSK Possible?
    By grnikolis in forum Map Monkey
    Last Post: 03-27-2005, 11:24 AM
  5. OSK clobbers comm port?
    By wi77iam in forum Software & Software Development
    Last Post: 03-25-2004, 12:12 PM
