Results 1 to 7 of 7
Thread: software to read/write to 8 DS1621s
    Fusion Brain Creator
    Mar 2005
    I need software to read 8 DS1621s.
    If you find it online I'll give you a cookie.
    If you write it for me I'll build you a board with connections for 8 sensors and specified wire lengths.
    I also need it to be able to write the Talarm value
    and also work in WinXP Pro.
    Constant Bitrate OdysseyPC's Avatar
    Oct 2003
    ACT, Australia
    Mmmm ... Cookie ...
    Schematic/Code (VB6)
    Caputer Mk. II
    '02 VX Holden Commodore Series II Executive
    MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
    Morex 60W DC-DC, Custom S/SDC
    OS/Software: Developing...
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    they have a pretty simple SDK with loads of examples for different programming langs!
    Mar 2005
    Quote Originally Posted by OdysseyPC
    Mmmm ... Cookie ...
    that only reads 2 sensors
    Oct 2003
    ACT, Australia
    Quote Originally Posted by greenman100
    My bad, I assumed you knew a little about electronics. I can let you know how to add the remaining six if you like.
    Hint: The DS1621's use a two wire interface for communications (SDA, SCL). You'll notice from the schematic that these are common to both U1 and U2. Secondly to distinguish between each device attached to these to lines an address is passed when communicating. This address is set by the pin A0, A1 and A2 on the DS1621's from the circuit U1 has A0,A1 and A2 tied like, in binary with A2 being most significant yields 000 (0 in decimal). U2 has A0 tied high with A1 and A2 tied low, in binary this is 001 (1 in decimal). Below is how the rest of the six devices.
    A2 A1 A0 Sensor No
    gnd gnd gnd 0
    gnd gnd vcc 1
    gnd vcc gnd 2
    gnd vcc vcc 3
    vcc gnd gnd 4
    vcc gnd vcc 5
    vcc vcc gnd 6
    vcc vcc vcc 7
    I think that should help you out ...
    Caputer Mk. II
    Mar 2005
    I know how to wire it, I don't know how to have the software read it!
    Oct 2003
    ACT, Australia
    Ahhh I see ... I could modify the software for you to read all 8 DS1621's ...
    ... you got PM.
    Caputer Mk. II
  1. Skinnable OBD software
    By kocke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-16-2007, 12:08 AM
  2. my OBD II Software
    Last Post: 04-06-2005, 03:53 PM
  3. MSDXM.OCX - Why oh why don't you fix that NOW?!
    By Zippy1970 in forum Media Engine
    Last Post: 02-28-2005, 05:36 PM
  4. Suggestion for the Software forum
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-02-2004, 08:55 AM
  5. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
