Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Anyone want another XM player? (NimbleXM)
  1. #21
    Raw Wave tj!2k4's Avatar
    Oct 2004
    comes up every couple of seconds or so. after changing the autoreset in the ini file, it says scanning channels instead, but never actually completes..
  2. #22
    Low Bitrate Erorus's Avatar
    Feb 2005
    NEPA
    Hmm.. well I added the XM check after I coded the channel scan, so maybe I missed something. Download this patched EXE and add the following to the INI to bypass the checking altogether:
    Code:
    ResetDB = true
    Check XM = false
  3. #23
    Dec 2004
    Los Angeles, CA
    Whenever I start it, I put in my correct com port (com port 1), it says something along the lines of "cannot run because the com port is already open".. So then it just shuts down. Now, this is on a fresh restart, without running FrodoXM too. What can I do??
  4. #24
    Feb 2005
    NEPA
    KingsDude: Windows is detecting it as a "serial mouse".. go to system in control panel, device manager, and disable the serial mouse.
  5. #25
    Dec 2004
    Los Angeles, CA
    OK.. Will give it a try tomorrow. Thanks!!
  6. #26
    Dec 2004
    Los Angeles, CA
    Nope, don't have a serial mouse. I tried disabling and reenabling com port 1 with no luck either.. Hmmm??
  7. #27
    Feb 2005
    NEPA
    does frodoxm work on com1? can other programs open com1? basically, the error is self-explanatory.. some other app must have the port open.
  8. #28
    Dec 2004
    Los Angeles, CA
    Dunno, but FrodoXM works on this port and thats the port it is set to. Even when I restart without opening FrodoXM, it has this error.
  9. #29
  1. Possible to split XM Direct cable to computer and XM commander?
    By Jemmi in forum General Hardware Discussion
    Last Post: 12-14-2005, 02:07 PM
  2. Stop audio player on XM launch?
    By chrishick in forum Road Runner
    Last Post: 10-26-2005, 07:59 PM
  3. XM Player, Channel List scrunched??
    By KingsDude in forum FrodoPlayer
    Last Post: 05-13-2005, 01:04 AM
  4. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 01:21 AM
  5. rca is going to kick *** with this player ....
    By KING ZOMBIE in forum General MP3Car Discussion
    Last Post: 07-14-2000, 07:51 PM
