Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: SLOW that FSB!
  1. #11
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Use the modded BIOS on this page and you can change your clock speed.
    It's also very easy to enable these hidden features yourself using modbin6 if you want to, but I used that 1.13 BIOS and had no issues.
    I think a better solution to your problem would simply be to wait a minute until your car cools down before booting. Or connect a tube from your air vent to blow on the motherboard. I have my alarm set to start the car/AC for two minutes when the inside temperature reaches 140 degrees.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  2. #12
    Constant Bitrate Hell-Stopper's Avatar
    Oct 2004
    =\ 40 c is hot wow......for the ppl who over clock cpus...we go up to 50ish and we try to stay udner that...but 40c ......that i think is a decent temp for that comp....other then that why dont u just switch its heat sink...will lower temp, maybe pro long the system.....the newer heat sink should be able to handle the cpu, if the fan dies....thats if u choose the right one too...
  1. Forum Really Slow
    By Quattro in forum Mp3car Forum Suggestions/Comments
    Last Post: 05-10-2005, 03:04 PM
  2. Slow Problem
    By Goose in forum PhoneControl
    Last Post: 03-22-2005, 12:13 PM
  3. ML8000... Slow? POS? some help please
    By bmo in forum Newbie
    Last Post: 03-13-2005, 06:38 PM
  4. mediaengine slow with windows me
    By qbics in forum ME Archive
    Last Post: 12-01-2003, 04:40 PM
  5. 500mhz with 83.3mhz fsb and a 2 MULTIPLIER!!
    By Krash in forum General Hardware Discussion
    Last Post: 06-24-2001, 01:23 AM
